Just order it for the model number
265-529 Replacement Belt Scotts S1742 S1642 Sabre ...
https://www.amazon.ca > 265-529-Replacement-Scotts-...
265-529 Replacement Belt Scotts S1742 S1642 Sabre 1542hs 42" Cut Lawn Mower Deck: Amazon.ca: Home & Kitchen.
TadaMark Replancement Lawn Mower 42" Deck Belt for John ...
https://www.amazon.ca > TadaMark-Replancement-Scot...
Replaces OEM: John Deere: M124895; Fits Models: John Deere: Scotts S1742 and S1642; Sabre 1542HS, 1542GS, 1642HS, 1742HS and 1742GS with 42" ...
Scotts S1642 (Deck 42") Riding Lawn Mower ... - V-Belt Guys
https://www.vbeltguys.com > products > scotts-s1642-d...
Scotts S1642 (Deck 42") Riding Lawn Mower Replacement Belt ... My belts arrived when you said they would and fit perfectly. I would order again. ... This was our ...
Rating: 5 · 6 reviews · US$13.84 · In stock
and more
https://www.google.com/search?q=Scotts+s1642+deck+belt
SOURCE: i need to see a belt routing diagram for a Scotts Mower
This is for a Scotts 1642. Picture yourself sitting on the mower looking down at the deck. Starting at the tractor pulley, the belt runs from the right side of this pulley to the left side of the tension arm pulley, around this pulley to the left side of the right hand side mower blade pulley, around this pulley, across the deck to the smaller left hand side idler pulley, then up to the left hand side mower blade pulley, around this pulley to the second (larger) idler pulley, around this pulley and back to the left side of the tractor pulley. If you make a small sketch of the deck pulley arrangement it will be easier. Keep in mind some of the pulleys are for the "V" side of the belt and some (The tension arm pulley & larger idler pulley) are for the flat side of the belt. Be sure the belt is not twisted and lays in a continuous circle with the "V" side of the belt on the inside before you start.
from http://www.ssbtractor.com/wwwboard/view_all.cgi?bd=lawn&msg=135
Please vote !!
SOURCE: install drive belt for scotts s1642 rider lawn mower
check size of belt make sure its correct make sure routing is correct andput belt on tension pully last you may have to pull on it to get it around it
