Question about Sony Televison & Video
How do i Reset sony kdf55wf655 without remote
Posted by Mark on
Admin UK
    Top Expert:
  • Sony Master
  • 34,660 Answers
To reset this set to its factory settings:
Press when in a Menu, to reset the settings to the factory defaults. Also user to clear Labels, Channels or Favourite Channels.
To reset the TV fully to its Factory Defaults:
Turn ON the TV while Holding Down the "RESET" button on the remote control, Press the POWER button on the TV. The TV will turn itself OFF, then back ON again. Release the RESET button.
Posted on May 22, 2021
2 Related Answers
Travis
  • 83 Answers
SOURCE: HOW DO I RESET THE LAMP TIMER ON A SONY KDF55WF655
Procedure for resetting your lamp timer,
Use the Remote Commander to put the set into service mode to display the service menus.
1. TV must be in standby mode (Power off).
2. Press the following buttons on the Remote commander within a second of each other: DISPLAY ==> Channel 5 ==> Volume + ==> POWER. The first service menu (TV) displays.
To reset the Lamp Timer:
1. Press the JUMP button 3 times on the remote to get to the Panel OSD mode.
2. Next press the remote channel 2 button 9 times to get to the Lamp Timer mode.
3. Press the remote 3 button, mute, then enter to reset the timer to zero.
It will take 45-50 seconds for the timer to reset. After the timer is reset you can shut the TV off. The lamp timer will remain reset (no need to save).
Posted on Jun 30, 2011
gopakumarg43
  • 76708 Answers
SOURCE: how do i reset a sony wega kdf55wf655 tv?
Hello
Turn ON the TV while Holding Down the "RESET" button on the remote control, Press the POWER button on the TV. The TV will turn itself OFF, then back ON again. Release the RESET button. OK.
Posted on Oct 08, 2011
Need a free manual for my Sony LCD projection kdf55wf655 tv
Sony has many manuals for their products on their support site. For the KDF-55WF655, start here: http://esupport.sony.com/US/p/model-home.pl?mdl=KDF55WF655 . Click on the Manuals, Specs & Warranty tab. Look for the Operating Instructions link on the left side of the site. This is a Javascript link so I don't know the full URL for the manual.
I hope this helps.
Yellow screen
my picture goes red shades and this means new bulb needed
sorry, but sounds like the same issue..... new bulb
I get hitachi with 3 year bulb warranty now for our school - cheaper in long run
How do you fix a lamp ballast board on 50 inch sony grand wega
The ballast board will need replacement you can get the sony Lamp ballast 146892712 used in the KDF55WF655 models, from www.tvrepairworld.com listed under the sony DLP circuit board cxategory
How do i reset a sony wega kdf55wf655 tv?
Hello
1helpful
6helpful
Sony grand wega KDF55WF655 6 red blinks
you can try these steps if this doesn't work I suggest replacing IC8002 on the power supply
Low HV Shutdown:
On the D Board.
Check IC8004/pin 7 should be 7.4v.
Check IC8006/pin 2 should be 2.5v if lower will trigger shutdown by causing pin 1 to turn on.
Check IC8006/pin 3 reference voltage 2.2v.
IC8006/pin 1 normally at 0v. If high turns D5007 ON which turns the latch circuit Q6532,
Q6530, and Q6527 ON and turns the AC relay RY6501 OFF.
NOTE: 6 blinks also can be Low B+ protection.
Unregulated 7.5 v from the power supply to 5v reg IC504 on the A Board. 5v to M Board Q2314
to CPU IC2300/pin 43. If 5v missing set will shutdown with 6 blinks
Sony KDF55WF655 TV ready green light blinks 30 times
Could be a bad lamp again. If this TV uses the XL2200 lamp, they are known for this intermittent behavior. If its not the lamp, a tech can access the self-diagnosis screen to see what's causing this failure.
michtech
2answers
Replacing the projection lamp
Try resseting the lamp timer following the info below: Procedure for resetting the KDF42WE655, KDF50WE655, KDF55WF655, KDF55XS955, KDF60WF655 or KDF60XS955 lamp timer:
1helpful
Reset Sony VPL-CX6 WITHOUT REMOTE ?
if you can't through the menu, you do need the remote.
Televison & Video Logo
Top Sony Televison & Video Experts
Ekse
Nasir Muhammad
Nasir Muhammad
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
