Sewing Machines Logo
Question about Euro-Pro Sewing Machines
I got a used Euro-pro sewing machine model # 464 XC. it doesn't seem to have a bobbin case under the needle. Shouldn't it have one? Where can i buy one?
Posted by Sheila Collins on
ADMIN Andrew
    Top Expert:
  • Euro-Pro Master
  • 57,110 Answers
Yes, they all need a bobbin carrier. Available here
https://a1sewingmachine.com/euro+pro-bobbin-cases.htm
Posted on May 17, 2021
I have a euro pro shark sewing machine. I just changed the thread for another project and cannot get the needle to pick up the bobbin thread. Any ideas?
Try installing a brand new needle. Bent/damaged needles will sometimes not pick up the bobbin thread.
Make sure the machine is threaded correctly. Check the bobbin--ie, it is turning the correct direction in the bobbin case and is threaded properly through the bobbin tension.
You might also try pulling the bobbin thread up to the top before beginning to stitch.
How and Why to Bring up the Bobbin Thread
I cannot get the bobbin to wind on my Model 1260 Euro-Pro. It was working fine the last time I used it. Any ideas?
Good day!
please try this simple tips:
Good day!
A sewing machine operator can often help themselves when their machine does not operate properly.
Here are some simple instructions, which if properly used can save time and mechanics service calls.
TROUBLE;UPPER THREAD KEEPS BREAKING;
This could be trouble;================Do this;
1.Top tension to tight================loosen tension 1 turn
2.Machine improperly threaded=========check threading
3.Thread twisted on guide post========"
4.Thread twisted out of tension======="
5.Take up spring bent or broken=======Check action of spring
6.Thread jumped off pull off finger===Check threading
7.Needle bent or burred===============new needle
8.Bad cone of thread==================try another cone
TROUBLE;LOWER THREAD KEEPS BREAKING;
1.Bobbin tensionspring to tight=======Loosen tension slightly
2.Bobbin threaded wrong===============check threading
3.Bobbin wound to tight or uneven=====try new bobbin
4.lint or thread on bobbin case=======clean inside case
5.Lint or thread inside hook==========clean inside hook
6.Bobbin case nicked bent or burred===check/change case
TROUBLE;MACHINE STARTED SKIPPING STITCHES;
1.Needle bent or burred===============change
2.Needle set in crooked===============Check
3.Thread jumped off take up spring====check threading
4.Thread jumped off pull off finger===check threading
TROUBLE STITCHES SHOWING LOOPS;
1.Forming loops on top of cloth=======Tighten bobbin tension
======================================or loosen top tension.
2.forming loops on bottom of cloth====Tighten top tension
3.Bobbin placed in case incorrectly===remove and replace
4.Bobbin thread slipped from under====check threading of
tension===============================bobbin case
5.Lint or thread in top tension=======clean between tension discs
Thank you and good luck.
1helpful
I have a Euro-Pro 9160 computerized sewing machine. I have had it about 5 years and never used it. I am familiar with regular sewing machines. My manuel says nothing about oiling the machine. Do I need...
Yes,
Go buy a can of canned air from a computer store and blow out your bobbin case area and any other lint you see.
Then place a drop of of on the needle bar (right above the screw that holds the needle in) and one drop where the hook (silver part) goes around the bobbin case (black part that holds the bobbin case) (see picture)
-Chris
1helpful
Needle will not pick up bobbin threat
Try flipping the bobbin spool so the thread comes off in the other direction.
Forcing means that the needle has been jammed against the sewing plate ant the needle is now out of timing with the bobbin pickup.
1helpful
I lost the bobbin casing
Sew4Less,com has a bobbin case listed for $19.95. Go to www.Sew4Less.com. In the blue box on the home page, fill in the blanks. Step 1: bobbin case. Step 2: Euro-Pro Step 3: 9025 Step 4 click Find Products and you're there!
1helpful
I have a Euro-Pro 473 model sewing machine, I?m converting into a Needle Felting Machine (adapter is Around metal with seven needles around it and is suppose to be attached into needle bar). I?ve removed...
If you're having the same problem we did, the attachment is installed too high on the bar. Move it down as far as possible and see if that solves the problem. If it doesn't, check to see whether the machine is belt-driven; did the belt break or slip off?
2helpful
3answers
Euro-Pro Shark Intelli-Sew 9110
you need a new bobbin case, only problem is finding the right one. I am currently wasting hours trying to find one for our 9110 intelli sew which has needle holes punched through it from where it jumps right out. I think lots of manufacturers know fine which parts fit the Euro-Pro but would like all of us to scrap them and go out and buy theirs!
1helpful
Won't catch bobbin thread
In order to see whether or not my euro-pro 9110 had a timing issue, the service rep had me change out the needle (making sure I was using anything but a Singer brand needle--they do not work in these machines). I re-threaded the needle, took out the bobbin casing and the plastic ring encasing the bobbin, then lowered the needle to see if the hook on the metal ring holding the bobbin actually catches the thread on its own. If it doesn't catch, it's a timing issue and needs repair. They can walk you through this process of troubleshooting and set up repair if need. Call Eruo-Pro's customer service center for sewing machine service and repair at 800-798-7395
1helpful
5answers
Thread keeps snapping on NEW Euro Pro 32-Stitch sewing machine
I have the same machine with the same issues. I am so frustrated! Here is how I am going to solve my problem in 4 simple steps:
Step 1. Open garbage can.
Step 2. Throw piece of **** supposed sewing machine into can.
Step 3. Cover garbage can, cursing loudly.
Step 4. Purchase a brand name sewing machine with a real warranty!
Top Euro-Pro Sewing Machines Experts
David Shaub
Colin Stickland
Colin Stickland
Marvin
Marvin
Are you an Euro-Pro Sewing Machine Expert? Answer questions, earn points and help others
