Question about GPS
Is it possible to get Navigation SD card for BV9384NV Boss Audio systems with Indian map on payment?
Posted by Nagappan Nagappan on
ray gallant
    Top Expert:
  • GPS Master
  • 73,420 Answers
Fixya has no way of knowing the answer
Posted on May 17, 2021
Hii i want to install navigation software in sd card for my car music system panasonic starda
  1. Insert the memory card in your navigation device.
  2. Switch on your navigation device and wait for it to start. ...
  3. Turn off your navigation device.
  4. Connect your memory card to your computer using a memory card reader.
  5. Install the latest application to the memory card. ...
  6. Install your map. [
I have a Boss BV9384NV that I just installed and it won't turn on I've checked all the fuses and color connected the wires what can I be doing wrong
Did you hook up the brake wire (it is usually pink) to ground? If not hook wire it with the ground wire on your stereo.
I have an aftermarket radio/navigation system in my truck. when I hit the navigation button it is looking for the following. \storage card\navione\navione.exe,check sd card. my card is blank
You have a defective NAV system, pull it out and send it in for repair or.... Just use your cell phone's Google maps app for navigation, it is far better then any car nav system.
I recently purchased a used car with parrot v5.11c system installed. But the GPS NAVIGATION SD CARD is missing. How can I get its navigation software?
usually software is inside the chip. On SD there're maps: you'd have to subscribe/buy a map subscription.
Apr 26, 2015 • Parrot GPS
I've purchused a 8gb sony sd memory card and when
It may not be formatted in a compatible format supported by your BOSS Audio system. Check the owner's manual of the unit,it should indicate which format it will support. Copy the data currently on the memory card back to a file on your PC/Laptop and reformat the card to match your BOSS unit. Have you tried other memory cards? It is also possible that the card has too large a capacity for the BOSS unit. T
3helpful
Doesnt go to navigation screen nextar x3-03
If it says it can't find map data then your SD card is corrupted.
It's a fatal flaw in the WindowCE 5.0 operating system that was used for Nextar GPS builds. Basically, if you have a power glitch while it's reading your SD card (contains the maps) then your SD card get's corrupted.
Don't expect any help from Nextar. You will have to get the original data from another person's SD card with the exact same model
2helpful
2answers
It doesnt have the maps
plug it in to your computer then go go on the nextar web site & download the maps.
GPS Logo
Top GPS Experts
ADMIN Canada
ADMIN Canada
Tom Chichester
Are you a GPS Expert? Answer questions, earn points and help others
