Heating & Cooling Logo
Sa Bakshi Posted on May 15, 2021
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Videocon split ac error code e 4 ? - Heating & Cooling
ADMIN Andrew
Level 3:
Top Expert:
  • Heating & Co... Master 66,907 Answers
  • Posted on May 15, 2021
ADMIN Andrew
Level 3:
Top Expert:
Answers
66907
Questions
Helped
5075550
Points
379435
3 Related Answers
A
Anonymous
  • Posted on May 06, 2008
SOURCE: error code c4
Indoor gas pipe thermistor faulty.
Anonymous
  • 51 Answers
  • Posted on Apr 13, 2010
SOURCE: yonan ac split mini 1.5 ton error codes E1
CHECK ROLLOUT SWITCH AND CHECK FOR A POSSIBLE
GROUND FAULT..OR FUSE..
ajajul
  • Posted on Apr 26, 2015
SOURCE: Videocon Split AC, Model VBS53
h6 problem create a machine showing a display?
H4 error code is shown on AC display what can i do to slove this problem
Full list of Gree Air Conditioner Mini Split Units Fault Codes. When error codes appear on the Gree air conditioner indoor display, this tells the user there is an issue with the Gree AC unit. The error code displayed will inform you of the issue or problem that is occurring with the air conditioner. Knowing what the error code means and its definition will help you to understand and troubleshoot the exact Gree air conditioner part that needs to be fixed, cleaned, repaired, or replaced. You can then clean, fix, or replace the Gree part yourself and save money. See below for all error codes that can occur on Gree Mini Split AC's.
Gree Mini Split Air Conditioner Error Codes - How To Fix
Gree Viero AC Mini Split PDF Owners and Troubleshooting Manual
GREE DUCTLESS AIR CONDITIONING & HEATING SYSTEM INSTALLATION MANUAL
Gree Mini Split Air Conditioner Part Names and Locations
INDOOR AND OUTDOOR UNIT
The Gree Air Conditioning Vireo System has onboard error code diagnostics. The outdoor unit will provide status indicators and the indoor wall unit and remote control will display error codes. The following is a summary of the codes with explanations...
GREE AC DIAGNOSTIC ERROR CODES
Gree Vireo Mini Split Air Conditioner Error Code F0
Refrigerant Leakage Protection
1) Refrigerant leak(s).
2) Indoor coil temperature sensor not calibrated.
3) Refrigerant flow is restricted (ex. valve, exv, debris)
Outdoor Unit Red Light Indicator - 9 flashes and 1 sec Off
Gree Vireo Mini Split Air Conditioner Error Code E1
System High Pressure
1) Over charged with refrigerant.
2) Blocked or dirty outdoor coil.
3) Extreme outdoor ambient conditions
Gree Vireo Mini Split Air Conditioner Error Code E2
Indoor Anti-Freeze Protection
1) Low return airflow.
2) Indoor fan speed is too low.
3) Indoor coil is blocked or dirty.
Outdoor Unit Yellow Light Indicator - 3 flashes and 1 sec Off
Gree Vireo Mini Split Air Conditioner Error Code E4
Compressor High Discharge Temperature Protection
Please refer to the malfunction analysis (discharge temperature, overload) in service manual.
Outdoor Unit Yellow Light Indicator - 7 flashes and 1 sec Off
Gree Vireo Mini Split Air Conditioner Error Code E5
Overcurrent Protection
1) Supply voltage is unstable.
2) Supply voltage is too low and system load is too high.
Outdoor Unit Yellow Light Indicator - 5 flashes and 1 sec Off
Gree Vireo Mini Split Air Conditioner Error Code E6
Communication Malfunction
1) Communication cable is wired incorrectly between indoor and outdoor units.
2) Indoor or Outdoor control board malfunction.
Outdoor Unit Yellow Light Indicator - Continuous On
Gree Vireo Mini Split Air Conditioner Error Code E8
High Temperature Resistant Protection
1) Incorrect refrigerant charge level.
2) Refrigerant metering device malfunction.
3) Compressor malfunction.
Outdoor Unit Yellow Light Indicator - 6 flashes and 1 sec Off
Gree Vireo Mini Split Air Conditioner Error Code EE
EEPROM Memory Malfunction
Control board malfunction.
Outdoor Unit Yellow Light Indicator - 11 flashes and 1 sec Off
Gree Vireo Mini Split Air Conditioner Error Code C5
System Configuration Malfunction
1) No jumper cap inserted on the control board.
2) Incorrect or damaged jumper cap on control board.
3) Indoor and outdoor units are not compatible.
Gree Vireo Mini Split Air Conditioner Error Code Fo
Pump Down or Gathering Refrigerant Status
Optional Service Mode
Outdoor Unit Yellow Light Indicator - 17 flashes and 1 sec Off
NOTE: All of the Gree Air Conditioner Model Numbers below are applicable for the error codes on this page...
Gree AC Vireo Models: VIR09HP115V1A, VIR12HP115V1A, VIR09HP230V1A, VIR12HP230V1A, VIR18HP230V1A, VIR24HP230V1A, VIR30HP230V1A, and VIR36HP230V1A.
Gree Mini Split Air Conditioner Error Code Charts
Gree Mini Split AC Remote Control Button Names
Gree Mini Split AC Remote Control Icons Display Screen
Gree Mini Split Air Conditioner Air Filter Cleaning Procedure
Need help with error codes on your Gree AC? Please leave a question below and we will be happy to help.
My videocon split ac showing on display e6 what is the problem
In this Videocon AC manual it suggests EEPROM communication failure. I don't know if this is your model because you didn't tell us what model you have. But the error could be the same no matter which model you have.
This error is internal to the control board so the only suggestion they have is to unplug the unit for 30 seconds and then plug it in again.
If you have the equipment to solder and a microscope or magnifying headset, you just might be able to see a bad solder joint and fix it if that's the problem. Otherwise you'll have to get a replacement control board.
https://videoconworld.com/media/gallery/for-vs5c3-vs3c3-vs6c3-vs5ch-part1.pdf
Page 10
Meaning of e6 arrear Videocon split ac
Communication error between indoor to out door, Check the wiring from indoor to outdoor, if good, your PCB is faulty. Repair it.
5helpful
2answers
VIDEOCON SPLIT AC SHOWS H6 & IS NOT WORKING
Videocon Air Conditioner Shows Error Of H6 Plz Tell Me The Solution.as urgent
3helpful
My videocon split ac is showing f8
my split ac is showing f8 on the digital screen
Videocon Split AC, Model VBS53 showing H6 Error. Please Help
Top Heating & Cooling Experts
Paul Carew
john h
