Televison & Video Logo
Question about Toshiba Televison & Video
Toshiba 50hp66 screen flashes. sound is good. you can see picture in the background
Posted by Chuck barton on
    Top Expert:
  • Toshiba Master
  • 76,851 Answers
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Pull up older posts or search the site by type in the brand name of your set, at its search box at the right column.. It will be best to replace the inverter board as card basis.
https://elektrotricks.blogspot.com/
Posted on May 16, 2021
5 Related Answers
Anonymous
  • 298 Answers
SOURCE: No picture, sound works. Screen flickering
It sounds like the video output isn't
working its most likely a component
failure 1 thing you could try is connecting
a rca cables from video/audio out on the set to
another set vid/audio inputs to see if it the video gets
through.This is a problem that requires technical
knowledge and test equipment to trace the video
signeal
Posted on Nov 22, 2007
Anonymous
  • 3 Answers
That problem is caused by the Y Sustainer board.
Posted on Apr 05, 2008
Jaime Hernandez
  • 2343 Answers
SOURCE: Toshiba 50HP66 Blank Screen with sound
I would suggest to read what other members have reported by clicking here.
Good Luck.
Posted on Apr 28, 2008
Paul
  • 224 Answers
SOURCE: Toshiba 50hp66
I think that the pop you heard was an electrolytic capacitor blowing its top on the picture frame board. If you are able to check this for yourself by looking on the board for the one/s with a bulging top or are a brownish/black colour like something has caught fire. And also in this situation smell can be of great help as it will smell burnt out but PLEASE before putting your nose or anything else in the tv take all necessary precautions against electric shock and discharge any electrolytic capacitors in the vicinity. If you are not able to do this yourself find a competant technician. Hope this helps.
Posted on Oct 07, 2008
roety
Eric Rotmil
  • 587 Answers
SOURCE: Toshiba 46in DLP No Picture, but good sound.
Hi my name is Eric,
I hope I can help you with your issue ,
Sounds like a bad lamp assembly , search for one online by model# for between $100-$200
easy to install yourself
Hope this helps, if it has solved your issue please click accept
But if you have more questions please respond and I will reply asap
Thanks
Eric
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Posted on Sep 09, 2009
signeal
2answers
No picture
try replaced DIGITAL PCB ***'Y
Manufacturer Toshiba
Part Number 72784100
Description DIGITAL PCB ***'Y
I have a Toshiba 50hp66 that the power light cycles from red to green with a simultaneous clicking of a relay on the power board. I check for power at a few points per the Toshiba service manual and iy is...
Check the fuses on the ysus & zsus boards. Are any fuses on boards open . Disconect power cabels to ysus board first {board on left} . put tv on . if the light is green the ysus board must be replaced.
Can hear sound but no picture on a toshiba plazma 50hp66
There's a possibility of the screen not getting enough voltage from the power supply so u should get tha voltage to the lcd cheked .votage has to be enough to run sound and video
wish u the best .
1helpful
Good Luck.
4helpful
2answers
Toshiba 50hp66
Have it fixed now before its too late the plasma is cheep and will fail. while its under make them replace it.
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
