Question about Sony Televison & Video
Help. I have a Sony kds60xbr1. It has a solid blue screen. It doesn’t have the blob problem and there isn’t Anything on the screen tv has been reset still has a blue screen there are no device’s attached. Anybody has had this problem fixed Please let me know. Thanks G.
Posted by George Dawson on
Paul Katynski
    Master:
  • 527 Answers
Https://www.sony.com/electronics/support/articles/00025437 This should help Good Luck!!
Posted on May 13, 2021
5 Related Answers
Anonymous
  • 5 Answers
SOURCE: Blue screen and red padlock
It sounds to me like a child lock function, which is usually what the screen + padlock is on TVs. Usually your original remote would have a button / sequence to unlock the mode. If you still have your original remote, look for a child lock button or refer to your remote manual (and/or TV manual for the child lock feature) to unlock the mode.
Posted on Jan 24, 2007
Anonymous
SOURCE: locked tv
I'm having the same problem. My screen is blue with a red lock in the bottom left hand corner. None of the buttons work except the on/off button on the television.
Posted on Oct 09, 2008
asnowman
John Snow
  • 788 Answers
SOURCE: blue screen after distored colors on a Mitsubishi WS - 55807
Your symptom sounds like at least one damaged convergence IC.
On Mitsubishi's you can sometimes rework the solder connections on each of these IC’s, although, if the convergence does not fix itself from time to time, you most likely do not have a bad solder connection. You will have a faulty IC. I recommend to replace them both at the same time because the chips legs can fall off due to the heat of the IC.
Please be sure to remove all of the white heat sink compound on the heat sink and apply a even coating over the back of the new IC’s. You should also bolt them down before you solder them in so that you have them at the correct height.
There are two and sometimes three very large IC’s that control the convergence in a big screen set. I believe that your set has two. They are secured to a very large aluminum heat sink. I think that the IC numbers will be IC8001, 80002.
The IC’s are large and black, you cannot miss them. They will usually have an STKXXX-XXX number on them.
This repair from a good technician will normally run from $250.00 - $300.00.
There are several schools of thought on the replacement of parts and I firmly believe that you get what you pay for, so don’t buy the cheapest IC’s that you can find. One company I worked for tried this and it only caused more work for the technicians, as we had to replace them with the more expensive ones in the end. I would think that you should be able to find these for around $60.00 each. If you can find the exact Hitachi part, or Sanyo, even though the numbers on the front are the same, and they look exactly like the $10,00 ones, they are better and more reliable.
I usually order my parts from Andrews Electronics in California, they will have the OEM components that you will need.
Their site is http://www.andrewselectronics.com/welcome.aspx
And their phone number is a 24-Hour Order Desk: (800) 274-4666
I recommend the phone order so you can talk to the person about the different types of IC’s that are available.
You can also try http://www.tvrepairkits.com/ , I have not tried them yet, but they do carry OEM or better parts.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up)
Please Note: If you can not rate this post with the highest rating, then please do not leave any rating. I am doing this for free and I do not think that any rating other that the best is needed.
If you need further assistance please comment to this post and I will try to help you further.
Posted on Jul 22, 2009
Anonymous
  • 135 Answers
SOURCE: Blue haze/blob near the center and lower right corner.
Failing optical block. check this website
http://sites.google.com/site/sonylcdrptvproblems/sonykdf-55wf655opticalblockreplacement
Posted on Mar 08, 2010
Anonymous
SOURCE: my sony wega 52 inch has blue spots and a blue blo...
do you have a picture of this problem
Posted on May 28, 2010
Blue spots on Sony WEGA KDF60XS955
Thats caused by a bad optical block. The cost of that repair will almost always be greater than replacing the TV.Thats a very common issue with alot of Sony DLP models which suffered that optical block issue with the blobs of color usually blue or green
1helpful
Blue ''blob'' of color on the screen of Sony dlp projection tv KDFE42A10
this is usually caused by dirt inside the light engine.  it needs to be sent in to sony or a rebuild company to be cleaned or replaced.  not user/operator repair....
1helpful
Blue Blob on 60 inch WEGA
http://sites.google.com/site/sonylcdrptvproblems/ This site will have all the info you need to fix this problem, or have sony possible replace your TV with a newer model as long as you have your invoice.
2helpful
2answers
Blue spots in Lt lower corner of the screen
NO you are Looking at your Light Engine cost 600.00 and up?
Blue blob on projection tv screen
CALL HITACHI THEY MIGHT HELP WITH REPAIR, HAS A BAD OPTIC BLOCK.
Please help-question about sony optical blocks
Talk to Sony about the blue blob issue, they may still replace the optical block for free.
If not, fix the blinking light TV.
Blink Codes
3X - Lamp cover not installed correctly, usually after lamp change, or cover detect switch is bad.
4X - Check fans (one or more failed to pass RPM test during power on diagnostics)
5X - Lamp ballast (power supply)
6X - Usually the thermal fuse - usually from inadequate air flow (fans dusty)
All other codes usually require a trained technician to diagnose and repair.
Blue screen?
This symptom is not related directly to the lamp.It looks dat the IC STK need to replaced.I think this must be remady of ur problem.
Televison & Video Logo
Top Sony Televison & Video Experts
Ekse
Nasir Muhammad
Nasir Muhammad
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
