Televison & Video Logo
Question about Samsung Televison & Video
My samsung tv Model: LN40B75OU1FXZA keeps powering on and off intermittingly. Any technical help available?
Posted by Chez chesley on
ADMIN Andrew
    Top Expert:
  • Samsung Master
  • 53,247 Answers
My Samsung tv keeps flashing smarttv and it won’t progress beyond that.
Sounds like either corrupted firmware or something went bang in a memory or controller chip, you could try a factory reset if you can find your model number on the samsung website. If you haven't tried this yet: unplug the power plug to the TV for about 10 minutes and then try again. Sometimes this will allow the caps to drain and clear any temporary faults.
Usually a factory reset involves holding buttons on the remote while pressing the power button etc. You should be able to find instructions on how to do this with your model number. Samsung generally is pretty good about this stuff being available.
Samsung tv un26c4000pd no volumn sound . Intermit buzz left speaker. Nice picture
Hi, maybe the audio power amplifier is faulty, this is an internal component that should be replaced by a qualified technical service to warranty that your TV will operate OK.
Model LNT4061FX/XAA Intermittent snow then picture. Is there a cure?
Intermitant snow means your tv is not getting signal continuously. Please check the input signal connection and source to your tv.
Samsung dlp 5065w keeps blowing fuse
samsung motherboards are bad for going out. they are 125 dollars online, if you have the technical skills to replace them.. basically just plug and play, with LOTS of screws to take off.
2helpful
My samsung t.v. keeps turning off
It's the problem of overheating in the power supply board of the TV.on the power supply board of the tv there are few capacitors and IC.any of this ic is got short or may be weak.so due to this when you start the TV the current passes from electric outlet to the power supply board of TV.but when the current passes from that weak/faulty part at that time current gets stopped or slow and the board overheats and TV shuts off. this is a common problem faced by many other users too.the possible option to solve this issue is to check the power supply board by a meter and continuity tester and replace the faulty component on the board which is short due to which power supply board is getting overheated.its bit technical job but yes its not at all a costly repair to do or get it done by the technician. for required parts it can be easily available from local electronic hardware shop.
This will help.
Tv keeps knocking itself off and comes back on indescrimently samsung 42 inch lcd
Hello, Good day.
It's the problem of overheating in the power supply board of the TV.on the power supply board of the TV there are few capacitors and IC.any of this IC is got short or may be weak.so due to this when you start the TV the current passes from electric outlet to the power supply board of TV.but when the current passes from that weak/faulty part at that time current gets stopped or slow and the board overheats and TV shuts off. this is a common problem faced by many other users too.the possible option to solve this issue is to check the power supply board by a meter and continuity tester and replace the faulty component on the board which is short due to which power supply board is getting overheated.its bit technical job but yes its not at all a costly repair to do or get it done by the technician. for required parts it can be easily available from local electronic hardware shop.
Hope this will help in solving the problem.....
2helpful
2answers
My samsung 46 in dlp tv keeps shutting itself off. anyone have any idea?
check the lamp door switch jump it out and try it. the contacts sometimes get oxidation and becomes intermitant.
Volume intermitently goes off but still have picture
Is this problem solved? I have it now, so I need the solution asap!!
Samsung flat screen plasma tv 40" with intermitent problem
Many of the parts in these sets are proprietory. The manufacture reps generaly change the complete board to service the sets.
The can be failed and you change them, but you would have to also find the cause of the failure. If not, when you apply the power back again, the new parts will fail again!
Jerry G.
Marvin
Marvin
