Garden Logo
Sumo Lee Posted on May 13, 2021
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hello i bought my kids a discovery kids aqau garden fountain and the submersible pump is set to high and theres a plus and negative sign on the side but i dont know how to turn it down. Can u help
  • The Spaminator
    The Spaminator May 13, 2021
    Hi Sumo Lee, we want to help you with your question, but we need more information from you. Can you please add details in the comment box?
    does the outlet pipe rotate like on different an angle to control the flow out .
  • Virginia Dyer May 21, 2021
    I recently bought one and a new garden hose to fill it up as it was not working as I wanted. We have created a lovely exterior area for the little devils to play in the summer, and since the size of the inflatable pool we added is huge, a good and fast hose was also a good addition. The thing is that the kids drink the water from time to time out of it when we are not around, and as you might know, a lot of the hoses in the market are toxic. So we found handy the review byhttps://cornygardener.com/drinking-water... before choosing one!
ADMIN Eric
Level 3:
Top Expert:
  • Garden Master 39,345 Answers
  • Posted on May 13, 2021
ADMIN Eric
Garden Master
Level 3:
Top Expert:
Answers
39345
Questions
0
Helped
794405
Points
588034
Reduce the power to the pump.
Sounds like a battery opperated pump, use a lower voltage.
2answers
We purchased a mushroom fountain from canadian tire and need a replacement submersible fountain pump pt300-70 can you supply the pump or advise where we can get one?
fixya site doesn't sell anything
most fountain pumps can be bought from nursery supplies , quality hard ware retailers and some irrigation pump and parts retailers
take your pump along as a sample to get the correct voltage and pump capacity
most are a simple impeller running on a plastic shaft and they fail because moss, weed , hair etc wrap around the shaft and jam the impeller movement
Apr 29, 2017 • Garden
Pump for old willies dilemma fountain by Henri studio
There are a lot of non submersible pump which are available in the market however, a submersible pump would offer you less trouble of piping connections and maintenance.
My little giant pumps intermittently and its the second one i had do this!
water being pumped have high solids content ? , get sample in clear glass let set overnight look at bottom closely , Lots of stuff settle down there ? if so your gonna need a filter of sorts to remove solids before pump gets a hold of it
How high does this pump example high high can fountain top be if pump is at bottom?
From the photo on the box, it looks like it will through a nice stream 4 to 6' high.
No details available though. Make sure the outlet of the pump is right at the water surface. You will need some rocks, bricks or a hidden floating platform to make it the right level.
If it is below water level, the fountain will be much smaller (may lose half of height for every inch below surface. 1" = 3 feet stream, 2" = 18 inch stream, ...
Fountain pump motor runs but no pressure to push water
You can try to force prime with a garden hose. Put the hose in ether side suction or discharge.
OASE fountain pump fluctuates height every other day.
No there is not 2 speeds. That model is asychronous so power fluctuations can affect pumping. How clean is the plug end and how dry is the receptacle? Is there is chance a extension cord is used [code violation almost everywhere] in this hookup? Perhaps it's just debris circulation and restricting intake?
54helpful
8answers
Parts for Garden Treasures 2 tier fountain
You can find replacement parts on amazon. click here Amazon com tier fountain parts and search for your part. Hope this was helpful. cheers
Apr 05, 2009 • Garden
2helpful
Pond pump types
There are basically two types of pond pumps to choose from - externally mounted and submersible. External pumps were traditionally used in water gardens. They sit outside the pond, with a hose that leads from a strainer in the pond to the pump. From there the water is forced either to a waterfall, stream or fountain. Because external pond pumps are often noisy and require extra plumbing, they are usually not suited for most backyard ponds. Due to easier accessibility and ease of repair, however, external water pumps are often the best choice for larger water gardens and public installations. Submersible water pumps are usually preferred by most do-it-yourselfers. They sit underwater where they are quiet and unseen. These pumps are easy to install, require no priming and stay cool thanks to the surrounding water. Submersible pumps draw water from the bottom of the pond, either through a strainer or biological filter. A hose attached to the outlet then feeds water to whichever water feature you have installed.
Top Garden Experts
Jay Finke
Jay Finke
john h
