Question about Logitech Computers & Internet
As you now know, water/liquid and electricity do not bode together well.
Purchase a new keyboard, that one is scrap.
Posted on May 13, 2021
SOURCE: spilled water on my toshiba satellite notebook
try : start-control panel -mouse and keyboard, if nothing weird appear,try to reinstall the driver for the keyboard,you'll find it here:http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=1311513&rpn=PSMA0U&modelFilter=M105-S3002&selCategory=3&selFamily=1073768663&selModel=1311513%7CPSMA0U
If it doesn't work you will have to change the keyboard and hopfully, there is nothing wrong with the motherboard
Posted on Jan 01, 2009
SOURCE: Logitech wireless keyboard not working
After changing the batteries and cleaning the corrosion out of the battery case, I pressed the connect button on the Logitech receiver, then the red restart button on the underside of the keyboard and it was fixed!
Posted on Mar 26, 2009
SOURCE: touchpad on dell vostro wont work
Sounds like a short to me...you probably missed some liquid as it does not take much...go thru the process again. I know thats not what you wanted to hear...but liquid on those things is a nightmare and you just never know where some of it went. A complete drying is in order...if it was a sticky liquid like soda....even when "dry" it can still short it out. If it was water...double check you got all the water...then let it sit out for a day.
Posted on Apr 24, 2009
SOURCE: Residue inside LCD screen.
Hi there.
Here is an in depth guide on how to separate the layers from the screen, it's imperative that you take extra special care while you do this repair because if you damage the screen it can be costly!!!!
http://www.laptoprepair101.com/laptop/2007/02/03/repair-notebook-lcd-screen/
Good luck
Posted on Jun 10, 2009
SOURCE: Dead Sidewinder2 Force Feedback
OK please don't underrate me for telling you the truth your controller is dead.. there is no magic word or driver or can of cleaner you can use to bring it back. that white residue around the main CPU is most likely caused from corrosion in other words water has shorted it out. but not all is lost because I lost mine the same way you did and I refused to give up on it. to be honest I was just too cheap to go buy another so I turned to ebay. I purchased a used one there for a total of $10.00 that had missing buttons and a busted handle I purchased it immediately and when I got it in I took my handle and buttons and placed them on the controller from ebay. It worked perfectly and I could not have been more happy. if this sounds like something you can do you can fix it for next to nothing.... I hope this has been of some help
Posted on Jul 24, 2009
that is huge post, and I like it,
most post here are useless short,
my guess the dismantly made this worse
put it in the attic, and in a hot attic
it will dry out fast and safely'
120F is best, hot attics.
ovens can not go that low so.... cant.
the best fix for floods are
to use IPA, flush it with IPA out doors
then when drip dried put it up in the attic or a hot tool shed or like my wood shed, runs hot.
let nature dry it out.
these keyboards are membrane switches.
and do not like water.
me, I'd chuck it out.
if no hot attic, it is doomed.
I see one on eabay for $5 used.
or at walmart get new one.
