Dryers Logo
Question about Dryers
Looking for a manual for Hoover Dryer 5050ED please.
Posted by LEON BOASE on
  • LEON BOASE
    LEON BOASE May 14, 2021
    Thanks Ray, when opened (perhaps 50 times) the link does not return the manual on the manuals on line website. There is a message at the bottom which says that they had found the manual 6 years ago and to click here. Unfortunately I have had manuals on typewriters and motorbikes and many other unrelated things. But after another 3 hours of searching I have had to give up.Thanks for trying to help me. Leon Boase
ray gallant
    Top Expert:
  • Dryers Master
  • 74,163 Answers
Http://laundry.manualsonline.com/support/hoover/clothes-dryer/hoover-5050ed-dryer-manual-5725083
Posted on May 13, 2021
Testimonial: "Thanks for trying Ray. The link did not help, got motorbike manuals and typewriter manuals and probably 20 or more others that I did not need."
HOOVER AUTO DRY 5050ED KEEPS STOPPING
hi there, I have repaired many of these dryers. It will be a faulty heater element, most likely. They cost about $40. If you get a tradesman to fit it, they will prob charge you about $200 all up. Maybe its better to buy a new dryer for around $300? Good luck.
Lance in brisbane.
2helpful
2answers
3helpful
1helpful
I need to download hoover washing machine manual HNWL7146-80
You can try going to http://www.managemyhome.com/ and looking up the model # there.
3helpful
2answers
Fitting the belt to the hoover 5050ed
nope,, but
all dryers are generically the same
remove the front panel and door
pull the drum
loop the belt around the drum, at apporximately the wear marks of the old belt
reinsert the drum
loop the belt around the motor pulley
pull the tensioner pulley hard against the spring to the end of its travel
loop the belt around the tensioner pulley
allow the tensioner to move back under spring pressure to tension the belt
rotate the drum by hand to make sure the belt is aligned and not coing to jump off the pulleys
reinstall front panel & door
26740a0.jpg the tensioner may be on the bottom belt run pusshing up, or the top run pulling down
breaking belts sometimes pull the tensioner out of its mounts, there is only one place that the tensioner will reinstall.
Its a standard whirpool dryer, rebadged as hoover, so the local parts guy has the belts rollers felts and glides as necessary, they are common to all the dryers whirlpool makes.
Needing Manual
do a search on googles for your model (include the word manual) and Ill bet many will come up. Most of the time you can get a operation manual at the company web site..
Sep 23, 2008 • Dryers
2helpful
2answers
Hoover 5050ed clothes dryer/tumble dryer
If the dryer hasn't been mounted before, you'll need to punch the blank slots through. At the bottom of the dryer (because you wall mount it up-side-down, so these slots will then be at the top), you'll see a vertical hole in one layer of the metal on the back to each side. Knock these through to reveal the holes where the bracket can go in. You'll also want to replace the control panel decal with the wall mount one that has all the controls up the correct way when wall mounted.
Jun 04, 2008 • Dryers
Can't get the dryer to work! - Hoover 5050ED Heavy Duty 5.0 Kg Auto Dry Plus
ditto and exactly 2 years later! Someone please help!
Top Dryers Experts
Marvin
Marvin
David Shaub
