SOURCE: 4 1/2 quart kitchenaid mixer head jumps when mixing
Adjusting the screw didn't work for me the first time I tried it. I was afraid of loosening the screw too much, and so I didn't turn it far enough. Turning the screw counter-clockwise until it stuck out several millimeters finally worked.
SOURCE: My mixer sounds like it
Hello there,
It is the same problem when you mixed bagel dough in it. The problem is that the motor needs lubrication. Moving parts require lubrication for maximum performance. There is a plastic gear inside the unit, if it is getting shredded it will begin to get stuck and strain before it will be able to mix a dough smoothly.
The plastic gear is meant to self destruct with time so as to save the motor from getting bad, so it is the plastic gear that need to be replaced in the kitchenaid mixer and if you intend to fix this yourself. Here are what you need to start the job and the steps it take to take it apart.
http://www.artisanbreadbaking.com/discussions/kitchen-aid.htm
Hope this was helpful to you.
All the best
Elect_Comp
