Televison & Video Logo
Goodday i have a problem with my Aim dled smart tv.The screen shows black but you can also see movement when we use a torch can someone help me please.
Posted by Felicity Meyers on
ray gallant
    Top Expert:
  • Televison & ... Master
  • 74,163 Answers
Call a local repair service self fixing never seems to work
Posted on May 12, 2021
5 Related Answers
Anonymous
  • 10594 Answers
SOURCE: The screen its totaly black
Right, Following is part number of required flexible wire..
" 1-864-761-11 " --FP-185 FLEXIBLE BOARD
It is available in Part Store for $26
Qualified tech will charge approx $100 to fix this camcorder.
Good luck.
Posted on Mar 04, 2009
SOURCE: toshiba tv goes black
the lamp has gone basicly there is a back light that lights the screen if this bulb goes you cannot see anything but it is all still there only way to fix this is to get a new lamp but sometimes the lamp is on a circuit board and the price is more then the tv is worth
Posted on Apr 29, 2012
Anonymous
SOURCE: What does it mean when it starts up in a black screen and cant start the normal windows
warning suggests that user is required to immediately backup all data and replace the failing hard drive with a new one. Hard drives may go bad due to mechanical component failure, electronic faults or firmware corruption.
Posted on May 11, 2013
gopakumarg43
  • 76851 Answers
SOURCE: My TV has black screen after trying to watch my recorded show. How can I get my tv back?
Sounds like The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Posted on Aug 31, 2016
airjoc
Rob Sinbad
  • 709 Answers
SOURCE:
If you have restored the TV to its manufacture factory setting and still have the same issues, and also have tried to adjust it manually, more likely your TV is going out soon and needs to repair by the certified electronic repair facility. Because of the brand/model, is really not worth fixing. By the time you invest fixing it, you can by a brand new TV from Walmart a Sharp, JVC and Toshiba 55' for under $300 bucks. In addition, there's no setting you can do or adjust to resolve your TV issues when it comes to LED colors malfunction. If this is a Dixon 55" TV, it an OK brands. Dixon, Sinotec, and Hisense are cheap TV, and I doubt you going to get a good service longevity out of those bands.
Posted on Jul 30, 2018
Hi I am trying to install dstv now app on my AIM smart tv, but cannot find it on tge google play app. Can anyone please assist me?
Its quite unfortunate that the AIM smart tv cannot download and run the DSTV now from the app store on its own.
I think the easiest solution is to get an Android box for it and enjoy your favourite shows on DSTV. Or better yet contact customer support for the AIM tv and report this issue.
Hope this was helpful?
TV went to a screen that is black with a message on top about smart cast display is not set up for casting
smart casting is someone trying to connect to the tv to cast what they are play. this should help you understand. https://www.youtube.com/watch?v=TFoeeZJPw0Q
How do I fix a flat screen tv that when turned on the screen is black with no picture?
place a turned on torch against the tv screen while tv on can you see a picture ? If yes then back light problem possibly inverter that powers the back light.
You tubesearch on tv faults for more insight on possible causes of black screen or no screen on Tv's
if no picture with torch then it might be main board .
Check you tube for ideas on possible causes.
Samsung LED UA40F6400 suddenly lost picture.
The tcon board or the LCD panel is faulty. You have to replace the TCON board to confim the fault.
http://electro-medical.blogspot.com/
Half a screen on my sharp aqous
If you have tried using different input devices, looked for loose contacts
in power outlet, RC Jack, cable and connectors, the TV might need service.
Rca L42phd37yx8 42' led tv blackscreen with sound wont show anything
Show a torch light on the screen (not too close) when the TV and program is running. If you can see the picture, the backlights have gone off. Anyhow, the TV needs attention by a qualified service technician.
My Insignia TV has a blue screen with parental cotrol the problem is I don't have a Control to pres display how can I unlock it???? HELP:(
Hello
When an Insignia TV is locked, it keeps you from watching all of your channels by only displaying a black screen. Insignia TVs are locked from a single button command on the remote control, so it is easy for you to lock the TV by accident. Since Insignia TVs can be locked so easily, it's important to know how to undo this command and unlock the TV yourself. So, unlock your Insignia TV with the push of a button and once again enjoy watching your favorite programs.
· Find the lock button on the Insignia remote control. The lock button is located on the third column from the left on the second row from the top of the remote.
·Stand within operating range of the Insignia TV, then aim the remote at the TV's receiver and press the "Lock" button on the remote control.
· Aim the remote at the TV and press the channel buttons to make sure the TV is unlocked. When the TV is locked, it shows a black screen and does not allow you to view anything else. If the screen remains black, press the "Lock" button again. If this doesn't work, change the batteries in the remote and start over at step
OK
5helpful
2answers
Hello, LCD Problem. I have sound but no image. Black screen. No access to the configuration menu. Someone can help me ??
I think your LCD TV lost back light that is why you have sound but no picture to see it as LCD TV requires back light to present picture on its screen.
Please intimate model and brand of your LCD TV to provide you more info.
Vizio LCD HDTV Screen is Black No Sound help
Not to be a smart alek but buy a new tv
Top Televison & Video Experts
Marvin
Marvin
