Many things to cause that. Put sheets of newspaper slid underneath between the feet. Run a wash, slide the paper out every 10 minutes to locate the area where the leak is. Wait for the cycle to finish. Pull the machine out and tip it towards the wall. Make sure it won't fall forward by getting someone to hold it.
Could be;
hole in the drum.
leaking pump
leaking hose clamps
perished rubber pipes
leak in the drain hose
The wet spots on the newspaper will pinpoint the leak area.
This link might help: https://www.google.com/search?q=hOW+TO+FIX+lg+top+load+washing+machine+leaking+from+bottom&source=lmns&bih=625&biw=1366&hl=en&sa=X&ved=2ahUKEwjv38KFltDwAhVS3XMBHaacBBgQ_AUoAHoECAEQAA
SOURCE: Leaks water from the bottom
Your pump is probably leaking. It's mounted right at the front of the cabinet to the motor. It's held on by 2 clips and 2 clamps, very easy job. Part number for the pump is 3363394.
SOURCE: Leak from maytag top load coin machine during spin drain cycle only
Possible that you would have a tub seal leak if it is only noticable during spin cycle. Possible that it "drips" slightly while in agitation, but not enough to notice it. While in spin mode you have a lot more parts moving as well as a lot more water pressure on the seal itself. Pump could also be leaking, but highly doubtful since it would leak a constant amount at all times. Good Luck!!! Jim
SOURCE: lg front load washer leaking from bottom of machine
I just fixed this problem - there is a rubber hose that hooks the bottom of the drum to the drain and recycle pumps - it is ribbed and it developed a hole. To confirm and repair (repair can be done from the front of the machine)
SOURCE: maytag top load washing machine leaking water from bottom
The machine is leaking water from the bottom, I think the leak is in the area near where the motor is mounted. Before we noticed the water comes from underneath the washer, we smelled like burning rubber.
Al Bana
SOURCE: LG front load washing machine water leaks with heavy loads
If your water is leaking with heavy loads, the first thing you want to check is the gasket (door boot) attached to the tub. Look for holes or rips in the bellows part(where the water settles) and around where it contacts the door. Any nicks or holes will cause leakage. Also, check the glass dome on the door towards the bottom. If it has dirt or hair buildup on it, it will leak with any pressure on the door.
