Briggs & Stratton Lawn-Boy Insight Series 21-Inch 190cc  650 Series Gas Powered Engine Variable Speed Self-Propelled Lawn Mower Logo
Posted on Sep 20, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How much oil to put in a 6.25 briggs and stratten
How much oil do i need to put in a 6.25 Briggs and Stratton motor when changing the oil?
Anonymous
Level 3:
  • Master 389 Answers
  • Posted on Sep 20, 2009
Anonymous
Master
Level 3:
Answers
389
Questions
0
Helped
273400
Points
1274
They hold APPROXIMATELY 20 ounces. Put in around 18 oz and start checking the dipstick and adding a little until it gets to the full or MAX or whatever it says on your particular engines stick. Each time you ad a little, give it a chance to drain down or you will get a false reading
What kind of oil in a22 ton briggs & stratton motor
BRIGGS & STRATTON ENGINES:
For temperatures above 40? F use an SAE30W oil. Using multigrade oil may increase oil consumption. Using SAE 30W oil below 40? F will result in hard starting and possible engine
bore damage. For temperatures below 40 ? F use
an SAE10W-30 or SAE5W-30 oil. Oil capacity for the 6 H.P. engine is approximately 5/8 quart (20 ounces; 0.6 liter).
Refer to Briggs & Stratton engine owner's manual for additional
information.
1helpful
Have a Briggs and Stratten 4.0hp Lawnmower that starts but sputters. What can I do to get it running smooth...What is the Spark Plug GAP?
How old is the fuel? Drain old fuel, use premium fuel and change spark plug and maybe air filter. I start mine in the Spring using quickstart. It also starts and dies a few times and eventually keep running. Winterizing the machine in the Fall prevents most starting problems in the Spring. If this does not solve the problem, see a mechanic.
6.5 briggs and stratton leaking motor oil through the filter area
How does it run? Is it back firing through the air filter box area? And although your stating it is oil is it actually oil or gasoline that is black due to getting dirty? Don't shoot me! I'm going on what information I'm reading what you submitted. If oil is it enough to show up quickly on the dipstick/engine oil level ? Get back to us and we can go further.
Briggs & Stratton 18 hp motor oil white
White oil in any motor indicates the oil has mixed with water . Drain the oil change the filter and find out how the water got in.
7helpful
2answers
I need a free copy (download) of a workshop manual to suit a Briggs and Stratten 375 petrol engine?
Workshop (repair) manuals are available for ALL of the Briggs and Stratton engines. They usually cost money though. The free downloads are only for the owner's manuals. You can do a search for Briggs engine repair manuals. There are many, many of them available.
May 22, 2011 • Garden
I have a troy built with a 21 hp briggs and stratten intek v-twin. i was cutting grass and it started running rough and made a couple of clanging noises and finely quit. and will not start. it will turn...
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&cad=rja&uact=8&ved=2ahUKEwjPwu3B5YH9AhVqkYkEHRwKCAIQFnoECAUQAQ&url=https%3A%2F%2Fwww.fixya.com%2Fsupport%2Ft5979403-troy_built&usg=AOvVaw0b3wiQJvQu7Er6dxxb4OY8
Top Briggs & Stratton Garden Experts
Jay Finke
Jay Finke
john h
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
