Question about Garmin GPS
My garmin s10 approach will not turn on - Garmin GPS
Posted by Wendy Jacobsen on
ADMIN Canada
    Top Expert:
  • Garmin Master
  • 41,712 Answers
Try a soft Reset
Restore the Approach Default Settings
  1. Power off the Approach by holding Up until it powers down.
  2. Press and hold Back and OK.
  3. Press Power until the Garmin logo appears on the screen.
  4. Continue holding Back and OK for 10 seconds.
  5. Release OK.
  6. 5 seconds after releasing the OK button, release Back.
Posted on May 11, 2021
ray gallant
    Top Expert:
  • Garmin Master
  • 73,786 Answers
Perhaps it needs new batteries
2answers
Were can i buy a strap for my garmin s1
No, the Garmin Approach S1 does not have replaceable straps.
The Garmin Approach S1 would need to be sent back to the Garmin Repair Center.
The Garmin Repair Center in Canada is Raytech Electronique in Laval, Quebec.
http://www.raytech.ca/en/services/repair_service.asp
Garmin approach S3 will not locate satellites
garmin approach s3 will not unlock
Jun 07, 2017 • Garmin GPS
Keeps beeping and displaying approaching turn
The "Approaching Turn" message is coming from an active navigation on your device. To turn it off, press and hold on the left side of the bezel (GPS), then press the lap/reset/quit key to exit the compass screen. You should then be in the GPS menu. There should be an item in this menu titled "Stop XXXX" where XXXX is "Navigating", or "Back to Start", or something like that. Select that option, and it should stop the navigation, and eliminate the "Approaching Turn" messages.
1helpful
Garmin Approach G3 screen freezing
Try loading or reloading the latest system software using the Garmin WebUpdater program.
The WebUpdater program will resolve most issues.
http://www8.garmin.com/products/webupdater/howtoinstall.jsp
You may also want to contact Garmin Tech Support for assistance.
1-800-800-1020
MY GARMIN APPROACH G5 WILL NOT TURN ON
Check the batteries are fresh and installed correctly.
Connect the unit to your computer and run the Garmin WebUpdater.
download the latest version of WebUpdater software
If the unit is currently up to date, reinstalling the update again will sometimes fix any issues.
1helpful
Approach G5 screen say cannot unlock maps as soon as you turn it on. Suggestions?
There's information on how to unlock maps on Garmin nuvi satnavs at http://www.fixya.com/support/r6197735-no_detailed_maps_found_support_routing. I don't know if the approach G5 would unlock in the same way but there's a good chance it would since they're both made by garmin. All I can say is have a look at the information on the link, check if the information you need is available on myGarmin and if the same files are on your GPS. If all these are the same it should work.
I put new batteries in , pushed on button, Garmin screen comes on and that's it and then can't turn off. Need to pull the batteries to turn off. Any suggestions. This is on a Approach G5
This sounds like a firmware issue try downloading Garmins WebUpdater Software and giving the unit a firmware update. If your are unable to connect the GPS to the PC you will have to send it in for warranty or repair. Here is a link to the Garmin Software you will require for the updates.
Hope this helps!
My garmin approach 3 will not acquire a gps signal. Why?
There are many reasons for a GPS to fail to acquire signals from the satellites. You should be outdoors with a clear sky the first time you attempt to get it to work. If it's worked before, but stopped working, it may be defective. Garmin recommends many thing to do at this link:
https://support.garmin.com/faqSearch/en-US/faq/content/YyCZrQHhuf6PO6qTKdvvr9
GPS Logo
Top Garmin GPS Experts
Tom Chichester
Steve P
Steve P
Aron
Are you a Garmin GPS Expert? Answer questions, earn points and help others
