Computers & Internet Logo
Error 0210 stuck key 69 can someone tell me what it is
Posted by aline diaz on
  • Anonymous May 10, 2021
    no PC told
    at all.
    why make it so hard to help.
    we can not see your PC.
    if it is one that is.
  • aline diaz
    aline diaz May 10, 2021
    just decide to format?
Don A
  • Computers & ... Master
  • 3,377 Answers
My guess is it is a programming glitch of the ALT key correctiable by BIOS modification rather than physically addressing. Such fixes are tried at your own peril and without guarantee of working (or even the computer working) after such.
https://aatayyab.wordpress.com/2019/12/19/when-a-key-on-a-computer-keyboard-gets-stuck-keyboard-codes-and-their-hex-scan-code-values/
https://answers.microsoft.com/en-us/windows/forum/windows_7-hardware/very-odd-0210-stuck-key-error/3885128d-6bb7-4442-a669-73b14bf58bff
That said, I would be awfully tempted to try an alternative keyboard (a rather dodgy idea if it is a laptop).
Posted on May 10, 2021
5 Related Answers
Anonymous
SOURCE: ERROR CODE "0210:KEY STUCK 39
I got the 0210 stuck key error on a Lenovo Thinkpad T61, pc would not bootup, made sure keyboard was connected and cleaned with aircan and then went into bios and via F1 on startup, then went to CONFIG then to Keyboard/Mouse then I disabled the TrackPoint. Boots up fine now but the red nipple mouse is disabled due to action mentioned above. Looks like a warranty fix for Lenovo since this is a newer laptop. If it was out of warranty i would just skip using it and leave it disabled. The trackpad works fine.
Posted on Apr 27, 2009
Anonymous
  • 111 Answers
SOURCE: error 0210: stuck key 01
I assume its a laptop. laptops some times get stuck keys, meaning one of the keys has not fully released after it was depressed. I recommend getting some compressed air in a can and give it a good cleaning. there might be something stopping git from popping back up. then give the keys a little work out. just mash the keys a bit. then turn it back on. if you still have an error, then you might want to consider replacing the keyboard. if you don't, it will not harm you pc in anyway...good luck
Posted on May 04, 2010
tagmonkey2k
tagmonkey2k
  • 117 Answers
SOURCE: Error 0210: Stuck Key 01
This is a system board POST/BIOS error code (nothing todo with Windows). The ERROR 210: is a standard POST (Power On Self Test) errormessage that indicates an error with the keyboard. The error condition is thata keyboard scan code was received from the keyboard when none was expected,after the keyboard was reset. If this occurs most of the time when you power on yoursystem, then it indicates that a key is sticking down or the key mechanical orelectrical parts are broken. Sometimes blowing out and cleaning out around thekeys will resolve this problem. Otherwise, you need to replace your keyboardwith a new (or at least a working) one.
Posted on Apr 19, 2011
Anonymous
  • 95 Answers
SOURCE: ERROR 0210: Stuck key 7B Press
There are issues with the ThinkVantage Button at boot as it doesn't do what its suppose to. Just use the F1(BIOS Setup), F11(pre-boot/recovery area) and F12(boot device selection).
Just a reminder to practice press and release when pressing a button. We sometimes get impatient and do a key hold down for a while rather than multiple press and release.
I hope this would resolves your ERROR 0210: Stuck key
Posted on Jul 20, 2011
rulds2008
Grand Canyon Tech
  • 3866 Answers
SOURCE: error 0210 stuck key 3a
You going to need to find a new keyboard for this unit. Try ebay.com you might get lucky paying $20 or so..
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Posted on Aug 09, 2012
T500 - error 0210 key stuck 3C
It sounds like a stuck key on your keyboard. You can try dusting off the keyboard with compressed air. If you see any dirt or debris you can try to remove it gently from the keyboard. You may have to replace the keyboard. If that is the case you can replace it yourself or have someone competent do it for you.
Error 0210 stuck key 3a
ERROR 0210: Stuck Key FF Press <1> to setup. please tell me how i can solve it..
I believe the problem here is a stuck key on your keyboard. You would have to contact a technician and replace the keyboard for you. Or if it is under warranty, you can call the manufacturer. One more possible reason is someone spilled something on the keyboard that made it sticky inside that's why the system is detecting it that has a stuck key. It still has the same resolution, you still might need to replace the keyboard of your laptop.
Thanks
1helpful
Machine has an error 0210 stuck key. Not sure what my daughter has done to her machine- can you help?
Machine has an error 0210 stuck key. Not sure what Problem with the Fujitsu Siemens LifeBook T3010 Tablet P
2helpful
4answers
Error 0210: stuck key 01
0210: stuck key 2B
Find a replacement keyboard for your model online, and/or have a local computer shop install it (or order and install it) for you.
6helpful
6helpful
2answers
Problem .......x61 tablet help !!!!!!!
Hello snapshots,
I have an x61, and you may want to check that all of the keys on your keyboard are not damaged, and that none of them are stuck in the pressed position. That is what the "stuck key" message typically means. If you check out the keyboard, and all the keys are fine, and if you are still receiving this message, try calling Lenovo support. There is an off chance that your keyboard (or other components) may be slightly defective.
Here is the link to the Lenovo site: http://lenovo.com/planetwide/select/selector.html
Hope this helps!
Jeff
Marvin
Marvin
