Good point :>) Connecting it to a computer, may show it as a volume, but that would be all. As I said, you have an issue that no one else has ever put into Google. That means it is very, very rare.
Contact Pioneer direct. It will probably have to go to a Service Centre and be connected to dealer software.
No updates
https://www.pioneerelectronics.com/PUSA/Support/Downloads
SOURCE: ciruit or block diagram of pioneer home theater system
The (schematic) circuit diagram is included in the service manual. A downloadable pdf copy is available here.
Hope this be of help. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
While I could not find it in the manual, I found that you must
go to the menu, open Sound Options and set Speakers to "Fixed".
Note: If you turn off the Surround Sound or DVD player combination you must then go back to the menu and turn the speakers back to Televsion.
SOURCE: pioneer XV-DV99 high definition DVD/Rewriter
vrea si eu o mufa de alimentare la pioner dv99 dac orct pe el cata_micutu90 ai mufa b
SOURCE: How to multi region my Pioneer XV-DV55
Most have "hack codes" but yours is in a select group of a few that simply cant be done with a couple pushes of a button.
As far as I am aware the only way to get thesemachines to play Region 1 discs is to have them chipped. A variety of solutionsare available, and it needn't be expensive (typically £30 to £70) but youshould be aware that any internal modifications to your players wouldinvalidate the warranty. Have a look at the following web sites for moreinformation:http://www.techtronics.com/uk/shop/50-000-dvd.html
http://www.maxking.co.uk/dvdmod.htm
http://www.dvdchips.co.uk/
I know you were looking for a free solution you could do in a matter of seconds and sorry it didnt work out that way. Regardless, I hope I pointed you in the right direction and feel free to ask if you have any more question.
Happy Holidays,
TJ
