Rather than spending too much more time fiddling I'd simply Clean Reinstall the printer which always works, lasts longer and actually saves time:
Power up the printer, if wired unplug it's USB cable from PC.
Go to Settings>Apps>Apps and Features to find and Uninstall the printer software.
Next type CMD in Start Search, right click Command Prompt result to Run as Admin, copy and paste in the following command and press Enter: printui/s/t2 (Note that there is one space before each forward slash).
Open the Print Server properties, Remove the printer's drivers for this printer and for any other printers you don't use presently.
Now type Control Panel in Start Search, open CP, choose Icon View. In Control Panel open Devices and Printers, right click the printer to delete the Printer and any scanner or fax of the same name. Restart PC.
Go to the printer model's Support Downloads webpage to download and install the latest full software package. Now is also the time to check for any newer printer firmware to install which matters a lot.
Extract Printer software, right click Setup file to Run as Administrator. Follow the setup screens closely as you install the software. For USB it should prompt when to plug in the printer.
If you have further problems reply back with results of each step.
I hope this helps. Feel free to ask back any questions and let us know how it goes. I will keep working with you until it's resolved.
Install new drivers for your printer on your laptop
Testimonial: "Print menu destination was found to be "Print to PDF" when another choice was correct = "Print to Epson ET-3600" Thanks for considering the problem."
Remove printer in settings.
Reboot Device
Reload Software and Drivers
Run Setup and add the SSID and WPA password into the printer control panel.
Video
https://www.google.com/search?q=epson+et-3600+wifi+setup
Turns out the problem all along was the command at the top of the print menu was "Print to PDF" and should have been "Print to Epson ET-3600" Thanks for your input --- much appreciated.
Yes, that would be confusing. Had a similar issue with work computers and 'Print to File'. Pleased it is fixed and thanks for the feedback.
Fortunately this was on the ground Larry. Multiple Dell Workstations, (all in ones, just a monitor with everything in them) connected on a Network to a HUGE Ricoh Full colour Office Printer.
he said wireless. ok.
problem solved , owner clicks wrong button, not print. to printer, SOLVED.
