Cameras Logo
Question about Cameras
Metabo ASC 30. What has caused it to stop working?
Battery charger for BS 14.4 Li doesn't turn on when battery is slid into it.
Posted by dan007 on
ADMIN Andrew
    Top Expert:
  • Cameras Master
  • 50,653 Answers
3helpful
2answers
I have a makita dss611 saw that has just stopped working
It could be 1 of the 2 carbon brushes when the autostop protection is activated replace carbon brush cb441 194435-6 is a normal problem when the working hours are arrived ,but if your battery is empty it will stopping at once a protection for li-ion deep discharge protection.
Li ION is the best to have allways 1 of the batteries on the charger ,if working and do not full unload it change after a while before its stopped its better for the expensive li-ion batteries but if forget one batterie to use over time ( because you want to save him well-intentioned ) to use it frequently is better when its to deep discharged it will not working anymore the charger will not accept the battery anymore if its deep discharged , to rewake it preloading it only like this way a safe as possible against fire hazard not use chargers of cars or other tricks do a full working loaden battery from the charger and connect with that other battery connect both to each other with 2 1,5 kwdr wires the full battery with the not accepted not working deep discharged battery that was forget for a long time BEWARE to do only connect a polarisation as the + to the + and the - to the - the poles parrallel connect to each other not longer then 3 minutes after that remove the wires and now put immediately the not working battery on the charger and see that its accepted again, if its not working repeat it one time again , not for 3 times its a real battery problem for garantee or replacement do not work on li ion with battery chargers for a car or other full overpowered chargers without knowledge do not open or disconnect wires inside the battery then the Makita battery is immediatly dead . because of fire hazard protection li ion full battery on empty battery + to + - to - not more then 3 minutes if it still not working within 3 minutes repeat it once again be shure the wires are connected correct from battery to battery to preload if there was an battery problem of an empty battery or dead battery.
Jul 23, 2018 • Makita Saws
What do the symbols on the Lithium Ion Battery and Charger stand for next to the prong slots and what are all those other prongs on the battery and charger for
Lithium batteries are very different from "normal" batteries. The other contacts are for the charger to check the cells individually. If one cell is discharged or charged more than the others it could cause it to fail early " or explode " in some cases. So these are very important and if something goes wrong with even one of the contacts the charger will usally say the battery is bad. Most lithium cells are 3.7v (LiPo, Li-Ion) but the new type is 3.3v per cell (LiFe). That should tell you how many cells it is.
Sep 30, 2014 • Drills
New ultrafire 18650 4000 mah li-ion battery. How do I let it charge for
Normally you should charge a battery for 14 hours on one tenth of the capacity. So if you have a charger capable of 400 mA/h you should leave it on the charger for 14 hours.
May 11, 2014 • Cameras
3answers
Problem with hitachi chargers
I live by hitachi, one of the good things about it is lowes will exchange them as long as you have a receipt and it's under 30 days. If not chargers are not very expensive, or you can send it back for repairs. I have 10 of those combo packs and never had a problem with a single one, for you to get 2 is a freak accident.
4answers
How to fix bl1830 battery when flashing red to green in charger
Take the liberty to disturb:
Our company is a Shenzhen battery factory, engaged in battery industry for 14 years, in 2010 began to set foot in the tool battery pack accessories industry, the MAKITA 18VBL1830 14.4V BL1430 opening 10.8V BL1013 series battery pack, Bosch 12V lithium battery pack and charger.Milwaukee 12V M12 1.5A 3.0A M12 M18 charger etc..Manufacturers supply quantity of large amount of pricewelcome to 86+15014034610 QQ 47018380 Mr. Miao
Metabo sbz 18v impuls drill has been sitting idol for years with a burnt out motor, have finally got round to fitting a new one. was working ok until I put the li-ion batteries in the charger. The charger...
If it is that old, the batteries are probably nimh (nickel metal hydride), not lithium, but either way, they will not be any good after sitting that long unused. Nimh have to be charged every couple of weeks due to self discharge, and lithium need to be charged every couple of months, but once a month is better. This is true if you use the drill or not, you have to take care of the batteries. They will have to be rebuilt or replaced. Oh, also make sure you are using the correct charger because if you use the wrong one, the batteries could catch fire and damage your home/garage/shop. Never leave a charger in use unattended. (Do not try to charge batteries and go to bed, very dangerous!) Good luck
1helpful
I need a battery for a metabo sb impuls hammer dril and charger drill perfect working order battery and charger lost in mooving house. has on bottom of drill were battery conects pa6-gf30 can you still get...
I saw them in the latest Metabo leaflet. They are serious producer and they shoudl keep spare parts for few years after they discontinue some product. Try to call to Metabo in your country. Juraj
4answers
Metabo 18V cordless drill lithiom ion batteries not taking charge
Some batteries develop 'memory'. Run the batteries down until they are completely dead, then recharge them fully. Do this a couple times to get them back to normal.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
9helpful
6answers
Camera keeps turning off
Digital cameras are very Voltage Sensitive. Using Nicad or NiMh batteries will not only , "Not" solve the problems above but will
actually aggravate the above problems for one reason.
Rechargable NiCad or NiMh batteries only produce 1.2 volts fully charged and will only give you 2.4 volts when used in pairs with this camera. This falls below the cameras desired 2.8 - 3.0 voltage requirement and will only result in about 30-40 pictures at most.
This camera requires a constant 2.8 - 3.2 volts to run properly. Kodak won't tell you this !!The camera was designed with Oxy Akaline batteries in mind.New alkalines will produce 3.2 to 3.4 volts in pairs but only for a short period of time.The issue with the Oxy Alkaline batteries is that they simply will not last very long in this camera due to its power requirements.
But there is a really great solution to the problem . You can purchase a CRV3 rechargeable Li-ion battery that fits right into this camera.
You will get a realistic 180-250 photos per charge.The Li-Ion battery maintains a constant 3.0 volts for a very long period of time
and will allow the camera to function the way Kodak originally intended it to and can be recharged. You will find rechargable CRV3 battery kits on ebay or other online battery stores at a very reasonable cost.
You can also use a Lithium Non rechargeable CRV3 battery that will give approx 250-300 photos per battery but you may
find non rechargeable Lithium batteries cost prohibitive.
I use the rechargeable Li-ION Battery exclusively in this camera and it functions perfectly since I switched. I have a pair
of CRV3 Li-Ion batteries so I always have a fully charge CRV3 ready to go.
For reference I was only able to get about 30 pictures with the high capacity 2800 Mah Rechargeable NiMH Batteries I used prior
to using the LI-ION Battery. I get on average about 175 pictures per full charge from the LI-ION Battery.
Top Cameras Experts
Marvin
Marvin
ADMIN Andrew
ADMIN Andrew
Are you a Camera Expert? Answer questions, earn points and help others
