Garden Logo
Question about Garden
PYT 9000 lawn tractor. Why doesn't PTO disengage?
Posted by ESDELDA FLORESS on
ENFORCER
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Garden Master
  • 38,673 Answers
Could just be a pivot point is dry. move the lever and give the deck a jounce with your left foot. does it disengage?? yes... clean and lube the pivots on the deck
Posted on May 04, 2021
ray gallant
    Top Expert:
  • Garden Master
  • 74,163 Answers
We are not there to look under it to find out might be a loose connector
How do you disengage the clutch after being left on when turning the engine off?
You can kill the engine with the PTO clutch on and then turn the PTO off before trying to restart because the PTO will auto disengage when the engine switch is turned off. The engine should not start if the PTO switch is on.
What is the gap gauge for craftsman pyt 9000 lawn tractor 26hp
If you are talking about the spark plug, I would need the model number of the engine.
Gap gauge for craftsman pyt 9000 lawn tractor
I am sorry, I can't help you, they could not answer my question.
Can you adjust the toeing out on the pgt 9000 model
There is no adjustment. Same problem here. Have to replace rims, bushings and spindle axles. Not cheap
Why is my LT-1018 PTO disengaging?
it has a bads pto the springs are weak and they or disengaging pto
My 16 hp b&s simplicity lawn tractor disengages the PTO while cutting the lawn on it's own. Is this alternator issue??
could be either
the voltage regulator will have to be checked for correct out put to run the PTO
It could also be a problem PTO unit that is drawing more current than the alternator can put out
have the system checked out by an accredited mower shop that has an electrician with experience
Jan 08, 2018 • Garden
1helpful
After slashing for about an hour the pto wouldn't disengage and I shut off the engine. Now I can't start the tractor because the lever won't move to release the pto. Any ideas what needs to be done to...
#1 You'll need to somehow release the pressure that is on the PTO. Or
#2 By-pass your safety switch (on the PTO) and attempts to restart that way.
Dec 18, 2010 • Garden
2helpful
2answers
Cub Cadet LT1042 PTO won't disengage
If its an electric PTO then the switch on the dash is bad, Its a lever type ungagement then the little break shoes that rub on the blade spindles are either worn out or mis adjusted.If it started when you changed the blade drive belt its possibly the wrong belt??
Top Garden Experts
john h
Marvin
Marvin
wadingriver
wadingriver
