Computers & Internet Logo
Question about HP Computers & Internet
My hp windows 10 laptop some keys are not working like H , G ,BACKSPACE ,VOLUME DOWN
Posted by archer stateking on
  • Larry Ng
    Larry Ng May 04, 2021
    no PC told, must the word HP PC.
    no model, it needs a new keyboard.
    to delay all that, any USB keyboard on earth works here, from a DESKTOP
    The model of PC or service tag is on one of 3 places, last one is on all.
    1: bottom sticker, tag
    2: big battery drops out? tag inside battery well.
    3: power on hammer ESC key. see BIOS
    see page 1, see model there on all HP.
    no photo posted of your PC, at all
    10,000 + models there. are.
    each with different keyboard
    and 50 countries of keyboards, made.
    The service tag must be told
    or no parts cab be found.
    all I can do is beg for facts.
Aron
    Top Expert:
  • HP Master
  • 2,323 Answers
The keys on your laptop computer needs to be replaced and have a person that repairs and fixes computers to have a look at your laptop and see if the keys can be repaired or not for your laptop.
Posted on May 04, 2021
  • Larry Ng
    all can be repaired
    only costs matter
    the keyboards for sure are sold
    even matching the unstated country
    getting the keyboard out can be tricky
    the manual at HP.com covers ever PC they made and now to do it, in the service manual,
    the problem is no PC told and not country told so is a HARD FAIL.
    that.
    the HP parts surfer is here.
    guess what is 1st question. omg country
    https://partsurfer.hp.com/
    note HP begging that and tag models.
  • Anonymous May 04, 2021
    1: GET IT FIXED IN A SHOP
    2: OR LEARN TO.(ask )(+
    NO PC TOLD, AT ALL JUST HP.
    by that I mean no PC hardware told
    as hardware is bad, and that must match the parts, fitted.
    most that post here are looking for magic
    like the magical, H/G/BS/vol , enable switch. that never exists.
    most keyboards die from coffee spills
    or just old age. (usage and abuse)
How can I fix a backspace button that has stopped working?
Make sure no bred crumbs are stuck under the backspace key. You may need to replace your keyboard.
68helpful
5answers
My keyboard will not type a double letter or backspace more than once without stopping first? Do you know why?
Disable Filter Keys in Windows 7 and Work.If Filter Keys has turned on in Windows 7 and your keyboard is no longer responding as you would like, follow these directions:
  1. Click Start
  2. Click Control Panel
  3. Click the Ease of Access heading.
  4. Click Change how your keyboard works.
  5. Remove all the check mark in the box next to "Turn on Filter Keys".
Enjoy :)
~ Vikrant (India)
Four keys as g,h, backspace and windows key is not working of my fujitsu siemens amilo pro v 1000 keyboard.
SOLUTION FOR Four keys as g,h, backspace and windows key...:-
I read this on a website and it worked wonders for me. TRY THIS:-
1. Just remove the adapter so that your laptop does not get any power.
2. Let the battery go completely empty and let the laptop get shut down with low battery automatically.
3. After laptop gets shut down, remove the battery and clean it with some cloth. Also clean the battery panel.
4. Press and hold the power button for kind of 30 seconds or so (laptop will not get ON).
5. Plug in the adapter to the laptop and start the laptop normally.
This process will fix it for you.
If the above does not work:-
1. Start the computer in safe mode with the last best configuration. It may also work for you.
Thanks,
- Naveen
Backspace key does is jammed up
I am providing you a link where in you would find a video as well, which would help you to clean the keyboard of your system,,.
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=125&prodSeriesId=3688868&prodTypeId=321957&prodSeriesId=3688868&objectID=c01631911
Hope this works.
Regards
Ken
44helpful
8answers
Volume control on Asus laptop. I need to turn up the volume!
Try the Fn key and F11 or F12 - that should turn up/down the volume on your Acer, depending on the model
Hope this helps - good luck!
6helpful
5answers
Backspace, g and h keys intermittently not working
I have had the same problem on my HP dv6700....backspace, h, g (maybe more) just randomly work and then don't work...must be a simple fix b/c this sounds like a problem for a number of people on different computers...we must be in some weird function or something? Any help?
9helpful
3answers
Hp dv7 keyboard issue
Hey guys, I just had this problem, I have alot of problems with my DV7 laptop, top panel started malfunctioning, then it thought i was turning the volume up and down by myself, also my g h ' and backspace stopped working along with other problems that I don't want to bore you guys with, whats the answer? Remove the battery for 10-15 seconds and clean the connectors and this has ALWAYS fixed all my problems. Hope this helps.
My HP ZD7260US 17" laptop has three problems.
It sounds like the volume button on the keyboard may be stuck in the volume down position. Your "c" key may have similar issues. You may want to have a tech check the keyboard connections for those buttons and clean beneath them...
Backspace doesnt work
in all likelihood your shift key is stuck. try pressing and releasing both shift keys in an attempt to "free" them. Also, check to ensure that "sticky keys" is not enabled on your computer(pressing and holding the shift key for about 10 seconds should pop up a window if it is. if the window appears, just make sure that the key is not "stuck" by windows).
Solution: mechanical agitation for your shift keys to attempt to free them, and a good thorough cleaning for all of your keyboard with canned air and/or a lint free cloth damp with dilluted isoprophyl alchohol to prevent this from happening in the future with these or other keys. Alternately, replace your keyboard.
Top HP Computers & Internet Experts
Mehandi Husain ...
Marvin
Marvin
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
