Question about Kenwood Audio Players & Recorders
How can i remove the protection mode displayed in my kenwood amplifier model KR-V9030 Thank you very much for your answer.
Posted by Mike Medina on
Arnie Burke
  • 7,336 Answers
Chec utube or pinterest
Posted on May 02, 2021
3 Related Answers
ThaMp3Doctor
ThaMp3Doctor
  • 8597 Answers
SOURCE: service / owners manual for KENWOOD KR-920B
This is as close as you're going to get:
http://inform3.kenwoodusa.com/manuals/kr910.pdf
Posted on Dec 15, 2008
Anonymous
  • 8546 Answers
SOURCE: I have a Kenwood KR-V9030
There is a chance that a common control may have developed a high-resistance or 'dead' spot and is causing your symptom. Turn the POWER OFF and operate every control throughout its range a number of times, especially rarely-used ones like Tape Monitors and the Mute control.
If it still doesn't work you might want to prove if its a low-level signal loss or a high level amp failure.
One way would be to run an RCA cable pair from the Tape Out to any other device (even a TV with speakers) you might have that accepts an audio input. If IT can't detect receive the DEAD Channel you're losing it in the preamplifying or source selection stages.
If it CAN be played externally, the receiver is losing it on its way to or at the amplification stage. Further isolation would require hands-on technical expertise.
Posted on Apr 16, 2011
Anonymous
  • 17 Answers
SOURCE: My kenwood kr v9030 is in protection mode, how do i shut it off?
Hop it was helpful.
Posted on Sep 21, 2012
Avr kenwood kr v5090
Have you tried the "Simulated" surround setting?
If you don't get sound in "Simulated" mode then you have probably lost the surround channels.
If you do get sound then your "Media"
is not recorded with a surround "Track". or the surround "Processor" may have issues that need to go to the repair shop.
When i turn on my kenwood kr-v990d it powers up for about 2min then shuts down
It is possible that the amplifier had encountered a fault with a higher current drain which had triggered it to a protection fault condition. The fault can be with your output drivers. Please check for short on the outputs fitted for both the channels. Use a meter after disconnecting to check for short in the drivers. Disconnect the positive and negative voltages to the output and see if the protect changes. Even a fault in the preamp stages that drives in high current into the output can shut the Amplifier. Sometimes this can be a noise which can be a HUM or HISS before the protect works. Faulty capacitors in these circuits also can cause similar issues and needs close observation.You need to confirm and replace the specific stages or outputs. If not there can be issues in the mother board. Maybe the protect circuit by itself is shutting off due to a faulty bias or there is a leak in any voltage/current sensing circuit. Also disconnect the speakers and test, if the amplifier comes out of the protect mode then check for short on the speakers.
My kenwood, kr-v5580 dont have sound
There can be many causes of this. Please see the link below as the most likely condition is protect mode as described there. One experiment is to remove the speaker connections completely to see if the unit remains on. If so, the problem is with the speakers. If not, then the problem is internal to the unit. Feel free to post any additional questions.
Dan
Link: http://www.fixya.com/support/r5390728-protector_means
2answers
My kenwood amplifier suddenly off when i turn the volume high?
You need to make sure you ohms are correct if there too low this will happen to protect the amp.
Item does not work
This unit is most likely in protect mode. This occurs when the receiveer detects a problem with the output amplifier section and that section is disabled. The most common failure parts are the output transistors. Expect a parts cost between $15-$40, Add in the local labor rate for the total repair cost.
Dan
2answers
Ppower on then standby problem Kenwood KR-V8060
This fault may be similar to a Harmon Kardon AVR1550 fault I recently encountered. I did all the usual checks e.g. testing for presence of DC on speaker outputs etc. but all seemed fine, then the fault cleared! Next day it re-appeared and attention was (falsely) given to the protection circuits as the amplifier circuits themselves were considered to be in order. The HK uses both voltage and current protection circuits and it was discovered that the current protection circuit was operating. Eventually the fault was found to be one of the 0.39 Ohm 3W metal oxide resistors that had gone high in value on the left hand channel. Of course your amplifiers fault may not be due to this but the reason for going into standby would probably be the same i.e. due to amplifier protection circuits operating. You need to check out all the output devices and those resistors on every channel, even surround ones you may not be using. Hope this helps.
3helpful
2answers
KR-X1000 Power Problems
Sorry, no freebies from what I see online. But, when you power up, does it play before it shuts down? This will help me formulate a better answer for you...accordianman
Top Kenwood Audio Players & Recorders Experts
Colin Stickland
Colin Stickland
David Shaub
Morne Olivier
Morne Olivier
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
