SOURCE: one igniter produces no spark. is it bad? can i
Looks like you may have a bad ignitor. Try adjusting the arc gap. Sometimes of the ignitor is too close to the burner, the ignitor will not spark. It may also be that te burner is dirty and needs a little cleaning to allow for the electric ignitor spark to arc accross, thus producing ignition. Good luck.
SOURCE: Camera won't turn on. I
Hi johnandmel7
If what you say is right, then you have your camera malfunctioning due to a corrupt flash software.
Therefore you need to visit the service center for canon and get it repaired as they would be having the relevant tools to install the software again on your camera.
Before doing that , please follow the below steps.
1 - Check the batteries in a similar device which uses them , to make sure they are in good condition.
2- If possible check with your neighbor or friend to give them their battery for the sake of checking your cam and if your cam starts up with their batteries then you have a problem with the batteries and you have to replace them.
SOURCE: 1991 Honda crx won't start
Try tracing the wires and looking for a worn spot in insulation that is grounding out, its a royal pain but might be the only solution, use wire prob and test areas where inaccessible. good luck
