Televison & Video Logo
After lightening my skyworth LED could not switch on even the standby red light is off
Posted by Xolani on
ray gallant
    Top Expert:
  • Televison & ... Master
  • 74,163 Answers
TIME FOR THE REPAIR SHOP OR BITE THE BULLET AND REPLACE IT LIGHTENING FRIES MANY COMPONENTS
Posted on Apr 23, 2021
5 Related Answers
Anonymous
  • 89 Answers
SOURCE: Standby LED blinks in red continuously KDL-46XBR4
If the Standby light is blinking at the front panel of the TV, it seems that there is an internal malfunction occurred in the TV. I will forward a link to a page where you can get more information and troubleshooting steps for this issue. http://www.kb.sony.com/selfservice/microsites/search.do?cmd=displayKC&docType=kc&externalId=C399467 Please perform the steps provided on the page. If the issue still persists then service of the TV is required.
Posted on Jun 16, 2009
Anonymous
SOURCE: My LCT3201AD is plugged in and the standby light
Remove the power supply and replace the three (3) capacitors soldered to it. They will be rated at something in the neighbrohood of 16v. Replace them with larger capacitors, something in the neighborhood of 35v.
Posted on Jul 12, 2009
Anonymous
  • 10 Answers
SOURCE: t.v on standby, red light flashing 3 times, wont switch on
Shutdown with a 3x blink pattern occurs if the 12v from the power supply (GF1 or GF2 depending on model) is lost at CN6153/pin 6 to the AU Board Q1224 to Sub Micro IC1205. The suspects, in order of likelihood, are (1) Power supply and (2) the AU board.
Posted on Sep 01, 2009
Anonymous
  • 541 Answers
SOURCE: Technosonic LCD1908 stuck in standby. Does not
There are several things that must happen before a DLP will turn on. The light bulb and color wheel must start first. Samsung had some color wheel issues. Check the bulb first. If it is good, most likely it is the color wheel.
Posted on Oct 14, 2009
electrotech1
Veril Gillette
  • 1126 Answers
SOURCE: Panasonic PTL500U LCD HiDef projector.
If you take the back off you might find a couple of bulged electrolytic caps on the power supply board that need change, or just buy a new power supply at www.partstore.com
Posted on Dec 22, 2010
How can I set key lock off on my skyworth tv? All the buttons are not working.
http://www.nekkedmeter.com/news-skyworth-tv-how-to-unlock-339.html#:~:text=Press%20%C3%A2%E2%82%AC%C5%93LOCK%C3%A2%E2%82%AC,factory's%20initial%20password%20is%200000.
SOLVED: How can i unlock the child lock of skyworth tv set ...
www.fixya.com > Forum > Televison & Video
Jun 25, 2013 - Turn on your TV. · On the remote, press the Menu button. The Set-Up Menu appears. · Scroll to the Key Lock function and set function to Off. · Press ... 1 answer
SOLVED: How to Unlock panel Key skyworth LED TV Model ...
Dec 26, 2012 - How to Unlock panel Key skyworth LED TV Model 32E65 Lock Panel ... down cursor to select "panel lock" then select right cursor to switch off ...
Videos as well
https://www.google.com/search?q=skyworth+tv+key+lock+off
I accedintaly turn on the disabled panel and i turn the skyworth 19e20 led tv plug out from outlet and when i plug it back the tv stay in standby mode, the remote control is not working, the panel also not working, i read few guid still not working, nothing is working. The tv is working properly its just the panel and the standby where remote cant bypas. Please help my dad will going to kill me.
Is there a on of switch and is the green or red light to be on
There is no main AC power switch on the BU series; it's in standby mode whenever it's plugged in.
When playing music normal LED color should be green. After no signal for 10 minutes or so it will turn back to Red (Standby)
2answers
Pioneer PDP-r06xe 50 in. Plasma Television Problem. During a Rain Storm - a lightening strike in my loft - the save system it has protect several electronics, but when I try to switch on - the TV it turn...
when switch ON it blinks 7time blue led - then switch OFF by SELF and blinks 8time blue led. Of-course when it switch off by self the TV swap the led from blue to red but the blinking Blue led is on the Receiver (The switcher on the TV is never blinking)
Motherboard red light stay on and computer won't turn on. Any ideas on what the promblem might be?
First try shutting down you're system. Than turn the PS off at the rocker switch (Back of PS). Ground you're self by touching the the PS. Remove you're memory and re-seat it. Than boot the system.
Check the standby LED. See if it lights green.
Pull the cmos battery and check its voltage. Anything under 2.4 volts replace the battery. Normally the MB LED displays green. (Standby power).
This means the MB is maintaining / charging the cmos battery. If the battery can no longer maintain charge this will cause the MB LED to turn Red. Built into the mother board is a small switch. When the system is shut down the MB maintains power to the cmos. If the standby switch fails to function correctly the LED will turn Red. Lets hope the problem is the cmos battery. The internal switch can not be repaired.
Cheers'
Mike
Start button not working standby light staying
The switch is for 'REC' 'Standby' and "PLAY".
If you leave it switched to "Play" and pull the plug and push it in to the wall receptacle (mains) it should start playing after a few seconds delay. The same for "REC". You use a timer unit on the power cord for those.
If you have the switch in the middle position and plugged-in, you should have a tiny Red LED illuminated. Push "Power" and it should start-up and be ready to use in a matter of a few seconds.
How to repair
check if it is plugged in,power button is pushed and standby led is lightening (red or green).
Model number not listed
That is a good question. My Model FTR184 Windchaser fan is not working either (has standby light on, and doesn't run, even when temperature setpoint is reduced to less than room temperature (in the PS - personal settings - mode), and more frustratingly, even in the FAN mode, where there is not supposed to be a Standby mode. That darned red Standby LED light just stays on no matter what mode I have fan in (though it does go off when I operate the Power on/off switch to turn everything off. So, I agree with Lease. Why isn't our fan model listed? And, of course, what is wrong with mine.
Top Televison & Video Experts
Marvin
Marvin
Lawrence Oravetz
