Washing Machines Logo
My laundromaid 1300M does not spin or drain - goes through the whole cycle.....
Posted by Yolande Seeber on
ray gallant
    Top Expert:
  • Washing Mach... Master
  • 74,163 Answers
SUGGEST YOU CALL A LOCAL REPAIR SERVICE FOR THAT MAKE
Posted on Apr 21, 2021
5 Related Answers
jsrock516
Jeff Rockwell
  • 5911 Answers
SOURCE: washer
The symptoms you describe are typical of a broken lid switch. The lid switch is located under the washer top on the right hand side. It is activated through a slot by a small plastic piece on the lid called a "lid strike". Make sure the lid strike is still installed and not broken. Make sure the lid switch itself is not loose, as well. There are two mounting screws along the washer tub opening that hold it in place. If the screws become loose the switch will not make contact with the lid strike when the lid is closed. If you need to replace the switch or lid strike, the parts are available at searspartsdirect.com. Just type in your model number and look under the "Washer Top and Lid" heading on the next page. The lid switch is listed as item number 22 (part #3355806) and the lid strike is listed as item number 16 (part #358684). Both parts combined will cost you about $30. If you have further questions and/or require additional assistance, please let me know. I hope this helps you.
Posted on Jul 22, 2008
Anonymous
  • 31 Answers
SOURCE: won't go through spin cycle
is the water being pumped ot f the drum. if the pump is not working it will not spin . put the washer on a drain and see if you can hear a buzzing if there is no buzzing i would take a look at your pump
Posted on Jun 26, 2009
Anonymous
  • 15935 Answers
SOURCE: Last drain and spin does not work
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 16, 2010
Anonymous
  • 15935 Answers
SOURCE: Wont spin after second rinse cycle regardless of what wash cycle
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!
Posted on Sep 17, 2010
Anonymous
SOURCE: water will not drain on
I found a bobby pin stuck in the out put or drain pump it caused the spin cycle to stop and the washer wouldnt drain
Posted on Sep 13, 2011
I have a Defy Laundromaid 1300m that doesn't let water in or start with the washing cycle need help please
Sounds like your inlet valve isn't opening. With it not opening the cycle won't start by default.
1helpful
I have a defy laundromaid. The machine doesn't reach the correct water level to start the washing cycle. However if I deselect wash and rinse options it does spin
good solid commercial unit 13 kg
could be a timer or control board fault
my best guess is
faulty water level sensor
?my laundromaid constantly drains water out before it has finished washing. i have had it for the past 4 years and have never been serviced. what could be the problem
problem program board is the most .logical answer as it thinks that it should be in the spin cycle but it is still washing
2answers
Hi my washing machine works perfectly fine but the water don't pump out srew out bottom filter is clean and I clean it on a regular basis. Defy 1300 laundromaid. Thanks please help
You probably have a rock or some object stuck in the pump blades. Take out the pump and turn the blades get out the obstruction
Wme8227b broken?
Possibly blockage in pressure system
10helpful
I have Defy Laundromaid 1300. I was getting an E9 message.
Hi, I get an OD (wording) on my machine after washing-dosnt rinse or spin... what can that be???
DEFY LANNDROMAID 1300M!!!
Top Washing Machines Experts
Marvin
Marvin
