Question about GPS
Hx850s GPS unit is no longer computing POS fix
Posted by Geoffrey Amu on
Aron
  • 1,970 Answers
You will have to buy a new GPS unit and GPS units can't be replaired.
Posted on Apr 20, 2021
My Standard Horizon HX850S is not receiving on any channels. GPS works fine. Transmission is fine as well. Thank you so much for your help. MO
Hi Marius,
Not being a nautical person, I can't give you any advice with the following exception: join yahoo group SPECIFIC to your radio Make/Model, they will send you all the info required, plus you can download manuals, diagrams and other goodies.
I hope this helps you.
Cheers,
Peter
Stuck on channel 69
Check the LCD and see if a key symbol is displayed. If so press Hi/Lo key until Key Lock is turned off.
Usb connector has broken off yet again.
We do board level repairs on the units so we can go the power jack for you. We charge $30 plus shipping. You can contact us at: [email protected] or www.ccl-la.com
Buddy
Corporate Computer
www.ccl-la.com
Unit makes sounds but no display
Hi
If unit is as per pic I assume it has external antennae. Ensure the multi pin plug is secure in the rear of the unit and also use a fully charged 12 volt battery, Has it been working before?? Usually a rear plug problem. How old is unit. Just had a another thought, check that the polarity is correct, ie pos wire to RED (Pos) on battery. Very polarity sensitive.
Cheers cbacer
Can't get GPS position fix - I've turned on the satellite receivers, gone outside...... any ideas?
make sure you have good batteries fitted, some batteries will not be strong enough to allow a good connection.
other than that you have a faulty chip and that's expensive repair
Gps connection
It can take a long time to get a GPS fix for the first time on a phone, either when new or after repair, as the memory will have been wiped. Leave the phone somewhere with a good view of as much sky as possible, with the GPS active for half an hour, and it will download the satellite data again. Then next time it should get a fix more quickly.
If your phone has an application for assisted GPS that downloads the satellite data from the internet, try running this.
Sometimes, there can also just be bad times for getting a fix, if the satellite geometry is bad.
2helpful
3answers
Blank Screen
Same Problem. I fixed mine with a baseball bat, hammer, and a cold beer. Lesson learned: NEVER BUY DELPHI AGAIN. NEVER..... Tell your friends. Delphi = POS
3answers
Call 1-8O5-225-669O GPS/GARMIN Update-Install-Download-Fix We are 24 Hour Available Call Now For Help
I fixed my C530 on my own. Garmin support will not give you this solution.
I attached the GPS to the computer with the usb cable. I used the file explorer in windows to view the file system on the GPS. I sorted the files by date. Then I moved the files that had a newer date than the last time the GPS worked, to an backup folder on my computer in case I need to restore the files to the GPS again. I than disconnected the GPS from the computer and restarted the GPS. The GPS works perfect now and doesn't enter the demo mode any longer.
1helpful
Gps malfunction
Try updating the firmware. http://www.magellangps.com/support/softwareupdates/SporTrak_BasicStd.asp I heard of the "no pos" message fixed after a firmware update, and also with fresh NimH bats. could be that it's just not getting enough power from the bats to make the connection. Good luck
GPS Logo
Top GPS Experts
ADMIN Canada
ADMIN Canada
Tom Chichester
Are you a GPS Expert? Answer questions, earn points and help others
