Computers & Internet Logo
Question about The Computers & Internet
My Craig DVD player keeps showing wrong region and will not play the DVD. How do I change the region settings??
Posted by Shari Wilson on
  • Anonymous Apr 21, 2021
    the answers are all here, and specific drives, at videohelp.com , make and model of drive.
    https://en.wikipedia.org/wiki/DVD-Video#...
    exact cures are buy a DVD drive that is region free
    cure 2, buy drive that can be switched, there is list of drives that can be here
    https://www.videohelp.com/dvdhacks?dvdpl...
    keep in mind drives made from 1996 to now , can or can not be set region free, , one must get the model of your drive first. and look it up here.
    there are only 3 cure
    buy only your region disks,
    hake your drive.
    or buy a drive this is region fee. (no country told by you, more your region)
    my guess you ment Craig, dedicated, DVD player right, and is NOT A PC right?
    no model told of your Craig. so, there can be no exact answers possible. ever. like that
    DVD drive is pure hardware and firmware,
    and the latter dictates REGION, and varies by model and version of firmware and country sold.
    ask at videohelp.com, on THEIR forum.
Simon Atkinson
  • The Master
  • 3,063 Answers
Most Dvd players can change the region settings. This must be done with the player EMPTY. Do you know what country the DVD you want originally came from? This will be needed to get the correct region for that disc.
You will need to go into the player's Settings menu. Somewhere in there there is a setting where you can swap between regions before you enter the disc.
If you comment below with the model number of your player I might be able to give you a more detailed method.
Posted on Apr 20, 2021
  • 1 more comment
    sorry not true "MOST", some are, some are not, I'd say most are not 1996 to 2021 or now.
    in fact the worst are Toshiba drives, and Philips is best. for hacks. OK learn to read the facts at videohelp first.
  • Anonymous Sep 06, 2021
    also varies country drive was sold ! or where exported TO.
    drives firmware versions.
    and the exact model of the drive.
    those are facts, but no DVD player told at all, full model so answers are guessing and or generic.
    dvd #1 goal by DESIGN was in fact to do just that block regions wrong.
    and does it first thing , as the dvd drive firmware executes.
    the only exception to this is some counties or regions 3,4,5 6 countries, sell region free drives.
    not one person here told his or her regions, but all dvd drives have region locks
    some can be turned off easy case by case
    this is why DVD was invented. to cure VHS weaknesses vast.
2answers
Need code for a craig dvd player
Hi, seems like your dvd player must NOT be region free, But if this isn't what you're after then please make your question clearer... The link below is a short youtube video showing how to set your dvd player to region free for FREE, The site is (your movie finder. Com) ....... CHEERS.. Multi Region Codes for DVD Players
Play my dvd's
The Region setting maybe incorrect.
To change the Region code on your DVD player, open Control Panel - System - Hardware - Device manager, and click on DVD/CD ROM drives, then right click on the DVD drive and click Properties then click on DVD Region.
You can enter a new region and it also shows you how many changes have been made.
NOTE you can make only 4 changes and the player will lock permanently on the 4th change.
If you want to play DVDs from any region you maybe able to upgrade the firmware to make it region free BUT if you make a mistake or installed the wrong firmware the player will be a piece of junk.
The best solution to make the player region free is to install a piece of software (Passkey for DVD) that allows you to play DVDs from any region and Passkey for Blueray that allows you to play Bluerays from any region.
There are several available on the Internet but my favourite is DVD-Region Free
www.dvdfab.com/products,free.htm
2answers
Unlock the dvd code
DVD REGION FREE & BLUE-RAY REGION FREE
To changethe Region code on your DVD player, open Control Panel - System - Hardware -Device manager, and click on DVD/CD ROM drives, then right click on the DVDdrive and click Properties then click on DVD Region.
You can enter a new region and it also shows you how many changes have beenmade.
NOTE you can make only 4 changes and the player will lock permanently on the4th change.
If you want to play DVDs from any region you maybe able to upgrade the firmwareto make it region free BUT if you make a mistake or installed the wrongfirmware the player will be a piece of junk.
The best solution to make the player region free is to install a piece ofsoftware (Passkey for DVD) that allows you to play DVDs from any region andPasskey for Blu-ray that allows you to play Blu-rays from any region. There areseveral available on the Internet but my favourite is DVD-Region Free From:-
1helpful
2answers
Message "wrong Region" appears in my Sony DVD -
DVD region is an anti-piracy method to block DVDs from other countrys to be played on a region where that DVD isn't available for selling. You still can watch that DVD by changing the DVD Player region code from options but be aware that you have a limited number of changes, after changes reach 0 you cannot change DVD region code anymore and your DVD player will be stucked to a certain region that you selected.
3helpful
2answers
DVD's wont play - says wrong region but they are compatible
To change the Region code on your player, open Control Panel - System - Hardware - Device manager, and click on DVD/CD ROM drives, then right click on the DVD drive and click Properties then click on DVD Region.
If you want to play DVD from any region you maybe able to upgrade the firmware to make it region free BUT if you make a mistake or installed the wrong firmware the player will be a piece of junk.
The best solution to make the player region free is to install a piece of software that allows you to play DVDs from any region. There are several available on the Internet but my favourite is DVD-Region Free
www.dvdidle.com/dvd-region-free.htm
2answers
Blu Ray Region settins
about changing ur region, theycan be changed from control panel.
go to control panel
go to regional & launguages settings
and change it to United States (US)
now reinstall ur HP's DVD program, and try it then.
i guess this will work..
1helpful
2answers
Philips DCP750/37 shows "wrong region"
Australian players are designed only to play Region 4 discs. United States discs are Region 1. It is illegal to change the Region code on a DVD player, so I can't tell you how to do it (ironically, it is the most frequently asked question about dvd players on Fixya.com - global world), but there are videos on YouTube that will show you how to do it - I would just enter "philips region code dvd" as your seacrh term. You won't find that exact model, but one of the codes in the video should work. Note that you will only be able to change the region code three times on a Philips - after that you will be locked out. So change it to Region 1 once, and never change it again.
-Tha Mp3 Doctor
3helpful
2answers
Wrong region.on screenhelp please
try to make it region free by using the steps below
1 Press power on
2 Press set-up
3 Select preferences menu
4 Press play
5 Input 251131
6 Press "Left" then "Down" button
Should show region code
7 Select region
8 Press set-up to confirm and exit.
or
Now on the remote control
3 Press set-up
4 Select preferences menu
5 Press play
6 Input 251131
7 Press "Left" then "Down" button
Should show region code menu
8 Select region free by hitting the 10/0 button, this will change the region to region free (ie 0)
9 Press set-up to confirm and exit.
or
1 Before powering on, open the lids, remove any media and leave it open so you can actually see the compartment where you place a disc.(this is how you get access to the preferences menu)
2 switch on unit from the side of the drive
3 Press set-up
5 Press play
6 Input 251131
2answers
1helpful
2answers
The DVD player does not recognize disks that it used to play before.
It sounds like the DVD region (a setting in both your OS and your DVD hardware) may have been changed. DVD regions are the agreed upon method (by entertainment companies, hardware manufacturers and governments) to limit cross-border sharing of media. Most valid (read: non-pirated) DVDs have a region code. Your DVD drive will only play DVDs with a region code that matches the DVD region code set on the DVD drive.
You didn't mention your OS but if you are running Windows XP then go to Start->Control Panel->System->System->Hardward->Device Manager and find your DVD player. Right-click the DVD player and select Properties from the menu and you should see a properties dialog-box with a DVD region tab. This is where you can change the DVD region that your player will recognize. Be careful, don't play around here, most DVD players have an embedded limit on the number of times (4-or-so) the DVD region can be changed.
Hope this helps.
-Ed
Open Questions:
Top The Computers & Internet Experts
NADARK
NADARK
A Kisling
A Kisling
nexrad_chris
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
