SOURCE: Green shadowing
if your tv is on warranty take it back to the supplier .if the warranty has expired then you will have to look at the convergence board it needs to be adjusted or replaced.also if you have speakers around your tv move them, that too can cause the green color problem.good luck my friend.
SOURCE: my tv has a green shadow behind everything on it
Tim,
Gee I'm pretty good with electronics and I've never heard that joke!
What you have there is a convergence problem. Your unit takes two STK392-110 Ic's at position numbers IK04 and IK05 respectively. Also check and replace as necessary Rk50 (2.7ohm /1w), Rk62 (2.2ohm /1w), Rk63 (150ohm /2w), Rk46 (1.8ohm /1w), Rk42 (3.3ohm /1w) And Rk43 (220 ohm 2w). In fact test all of the 2.2ohm resistors in the yoke return just out in front of the amps for change in value.
Also make sure to use Sanyo original Ics and not some asian knock-offs which are readily out there.. Get them from Acme in Florida http://www.acme-sales.net/index.shtml and rest assured you're getting Sanyo originals..
Bill
SOURCE: Panasonic PT-51HX41 rear projection tv showing shadow/double images.
Unplug the TV from the ac wall outlet for about 4 minutes then plug it back in and turn it on. If it still has a double image then tell me if it's affecting the menu screen from the TV (not the cable menu). And is the double image in red and blue?
C-Dog
SOURCE: red & green shadows
Replace the two STK392-120 Convergence Ics you can get replacements at the following link with step by step instructions on how to do the repair.
http://servicemanuals.vstore.ca/
SOURCE: cant find code for emerson lc320emx toprogram to dish remote
Try 1465. However, you will still have to use your other remote to turn the unit on. :(
