Question about Optimus Audio Players & Recorders
Optimus stereo wont power up - Optimus Audio Players & Recorders
Posted by Paul Dunstan on
Krn Choudhary
    Problem Solver:
  • 12 Answers
  1. Verify the Unit Isn't in Protect Mode.
  2. Check the Fuses.
  3. Check the Pigtail Connector.
  4. Check for Power at the Head Unit.
  5. Check for Ground at the Head Unit.
  6. Bench Test the Head Unit and Replace if Needed.
Posted on Apr 18, 2021
I need a servic manual for and optimus sct 86 Stereo cassette tape deck
Contact radio shack as that is their in house brand. I would suggest replacement as almost any other brand would be an upgrade over the optimus.
Optimus stereo receiver universal remote codes
go to link below and click the green "Notify Me" button when this item is stocked. We will inform you when we put one in stock. You must purchase a new OEM remote, universals will not work. OPTIMUS STA3750 3760 Remote Control
I have an optimus stav 3670 stereo reciever that wont turn on. I have located 3 fuses, all test good. No lights, click, or any sound or reaction when power button pushed. I'm hoping there is a 4th fuse...
Mike, sounds as if it's not getting voltage to the remote control receiver circuit? Meaning that there is a low voltage (5volts) that sits there and waits for the signal from your remote to turn the unit on. This is also through the front power switch which is also tied to your on-off power relay. I would check for 5 volts around that. More that likely you a 5 volt regulator shot. Hope this may help?
Nov 25, 2013 • Dryers
LG optimus wont power on or charge
you may have over heated the battery. does the notification LED blink or anything when you attempt to turn it on?
I need a user manual for an optimus system 738 micro stereo component system 130-1286
i have one call if you need it!! 2076919126http://www.fixya.com/imageupload.aspx?f=images
Top Optimus Audio Players & Recorders Experts
Marvin
Marvin
Lawrence Oravetz
NOEL
NOEL
Are you an Optimus Audio Player and Recorder Expert? Answer questions, earn points and help others
