Question about The Audio Players & Recorders
Where can I buy the cable that connects the Boston BA 745 subwoofer to the computer?
Posted by Cary H Castro on
ray gallant
    Top Expert:
  • The Master
  • 74,163 Answers
Search for it thru amazon or GOOGLE it
Posted on Apr 17, 2021
Boston Acoustics BA 745 speakers. Plugging in a headset does not override the speakers.
the bass unit powers speakers. there is no headphone jack. Now on your computer there is, you can configure to turn off speakers when plugged in.
Boston be a 745 computers subwoofer speaker fuse replacement
Take the old fuse to any reputable electrical supply store, for example :Tandy, Radio Shack.
I have old Boston BA735 digital speakers that I am trying to get to work with a new HP PC. Do I need drivers? There are 6 places to plug in speaker cables on the back of the PC. Which ones do I use?
Many of the new sound cards and especially sound cards on OEM do not support digital speakers without buying additional connectors. (Not sure why. I have these same great speakers for years and they are wonderful.
- Check if your sound card ha an SPDIF connection option. - Check the speakers in the device manager to see if you can toggle the "digital" option. - I also have read that some versions of the BA 735 have an analog option on the back of the subwoofer if you need to bypass digital. (mine don't, so I don't know if this is accurate)
I miss some cables of the Digital BA735. Which cables I have to purcahse?
You need a set of RCA cables, Red & White, you will need two sets. The Cables, simply wire color to color. You nay also need, some adapters, if you cannot get RCA to Phono Jack, on one end. To make with PC, Output Socket, you need an 3.5mm Phono, Jack, and on the other end, the RCA, for connection to the Speakers
http://www.ehow.com/how_4793807_wire-boston-acoustic-proseries-amp.html
http://www.ehow.com/how_5412465_connect-boston-acoustics-ba-speakers.html
How to wire the speakers at above two links.
http://forums.overclockers.com.au/showthread.php?t=229490
Drivers above.
The small speakers produce sound but the sub
I have Boston BA745 speakers and want to use them with my new HP Pavillion Elite HPE computer. How do I get them to work?
I have a Boston Digital BA735 Subwoofer. I would like to connect it to my current system. I running on Microsoft XP Home Edition 2002, Gateway FX400 Pentium (R) D CPU 2.8 DGhz, 2.8 Ghz 500MB RAM. Can I do...
I have a Boston Digital BA735 Subwoofer. I would like to connect it to my current system. I running on Microsoft XP, Dell Latitide 610.Can I do this? If so, do I need a different audio cable connector cord? Thanks
2helpful
2answers
Can the Boston BA 7900 be converter to use with TV or DVD Player?
Yes, but so far I can only get the 2 front speakers and subwoofer to work.
You need a wire that converts a headphone-style jack (like the green one with the Boston speakers) into a red and white AV connection (typical CD/DVD, etc. connection). I've had this connector for a long time and I'm guessing it's under $15. You connect the green Boston speaker connection to the converter end (mine connects to the back end of the headphone-jack (which has a hole for the connection) and the red/white AV connectors to your TV.
I'd been trying to solve the problem too for a long time. Only problem is that I can't get all 5 speakers to work because I think the red/white connector doesn't work with all 5 speakers. I have yet to figure out how to make all 5 work, but the system gives great sound anyway. You will have something like a 5.1 system with your computer speakers, the Boston speakers and subwoofers.
One more issue is that if you connect it directly to the TV, you have to manually turn the Boston speakers on and off.
Moved across town and now my BA 7800 surround sound speakers not
No expert solution here - just a suggestion. Did you check the 9-amp fuse below the "Out to PC" connection on the subwoofer?
Boston BA 745
so what you want to do is have both the parts play on both the speakers on the same time, am i correct?? was there a utility or program that came with your speakers that may have proporties to change this setting??
Top The Audio Players & Recorders Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a The Audio Player and Recorder Expert? Answer questions, earn points and help others
