Question about Daewoo Washing Machines
I have Daewoo washing machine 7kg DWD-F1013S am looking for the control panel to buy my panel is bad how can l get it please
Posted by Ojuederie Philomena on
Aron
  • Daewoo Master
  • 2,088 Answers
EBay and buyspares.com and Sears official website and also on Amazon too.
Posted on Apr 17, 2021
5 Related Answers
Anonymous
SOURCE: Daewoo wash machine air power 7kg Model DWD-F1013.
i bought used but good working daewoo f1013 washing machine in dubai,
i can not spin. no drying. i dont have user instruction manual.
please help
Posted on Feb 11, 2011
Anonymous
SOURCE: daewoo DWD-F1011 PFE error code
I hd zs problem before,no problems in z water outlet,z pump
Posted on Dec 19, 2011
william rodriguez
  • 958 Answers
SOURCE: my Daewoo does not want to spin, any suggestions?
first does all of the water pump out when wash cycle is done? if not then check your drain lines and see if pump is coming on. if it is not then it wont let the washer spin,
Posted on Jun 04, 2014
xkikbxr
  • 788 Answers
SOURCE: Daewoo DWD-F1011 1E error code I have a daewoo washing machine model DWD-F1011 and it start working the wash before no working spin and gives error code 1E. Any idea what that might be?
I do not believe that is a 1E I think it's an IE error code which would be water inlet wiring or something like that. Here is the code list, scroll down until you find IE, Daewoo errors start at E2, hope this helps.
http://removeandreplace.com/2015/11/02/daewoo-washing-machine-error-fault-codes/
Posted on Aug 30, 2016
My Daewoo does not want to spin, any suggestions?
I believe the EO code means the pump is blocked, and you will have to clear the pump for it to work again.
5helpful
I have a daewoo 7kg direct drive washing machine DWD-14ODS i put a load in it got a couple ov minutes into the cycle then started bleeping and is displaying LE on the screen there is some water in the...
'LE' stands for Lock Error. There is likely to be a problem with either the lid/door solenoid/lock or the 'lid/door closed' sensor requiring a service engineer's attention I suggest. Sorry ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
3helpful
3answers
I have a Daewoo DWD FD1233. It's brand new & 12 minutes before end of cycle it comes up with E8 as an error. The machine wont spin after that. What can i do? Lots of wet washing.
Daewoo e8 - engine error! or Bad soldering.
Remove the control panel (the one in which many connections). Remove the rear rubber compound around contacts blue relay.
Resolder them. And it will be all ok!
Or - remove the entire back of the compound and look for where the bad soldering (cold soldering ). You can see it - blackened or exfoliated. Just solder all.
7helpful
5helpful
2answers
Daewoo DWD-F1011 PFE error code
2answers
Error code E8
Most likely a control or motor issue. Probably should call service.
Washing Machines Logo
Top Daewoo Washing Machines Experts
Paul Bade
Fahr Quad
Paul Carew
Are you a Daewoo Washing Machine Expert? Answer questions, earn points and help others
