Computers & Internet Logo
Question about The Computers & Internet
The contrast on the screen is faded, tried to adjust the contrast but no results ( any tricks to adjust the contrasts?)
Posted by joe jackson on
Eric the half a bee
    Top Expert:
  • The Master
  • 37,040 Answers
Depends on what.
Posted on Apr 17, 2021
1helpful
The screen has good contrast sometimes but mostly it is faint. can this be fixed?
The displays can just be swapped out, or an electronics engineer can replace the capacitor that is on the rear of the display board. The same issue happens to microwave oven and radio displays.
First though, you can try spraying the works of the button wheel with Switch cleaner.
3answers
CONTRAST ADJUSTMENT
it is best to shut the color level to the lowest setting then try t balance the screens to achieve the best black and white picture. then turn up your color level. Your brightness level should also be set to 50 % then when you adjust for the best B&W picture. You will have better color and brightness when you reset your color and brightness levels.
I am further looking into ur problem..
Goodluck..
HOW TO SET BRIGHTNESS OF THE SCREEN?
Dear User...
You can adjust the brightness and contrast of your monitor to improve the readability of text and to make digital pictures appear more like they'll look when printed.
To improve the results when adjusting the brightness and contrast settings for your display, use Display Color Calibration. (Display Color Calibration helps you adjust these color settings and others.) For more information about calibrating your display color in Windows, see Calibrate your display.
The way you adjust brightness and contrast varies and depends on your specific display.
Brightness and contrast buttons on the front of the monitor. Some monitors have brightness and contrast controls on the front and use the standard symbols shown in the following image.
On-screen menu. You can change the brightness and contrast settings for some displays by using an on-screen menu, and then setting the brightness and contrast in the resulting menu. Many times, you can view the on-screen menu by pressing a button-possibly labeled Menu-on the front of the monitor.
Thanks....
Screen too dim
You can try adjusting the screen contrast by pressing [2nd] and using the up and down arrows. Up will make it darker and down will make it lighter/more faded.
I just had my Emachines D520 laptop display replaced because it was cracked. The new display is too bright, and the Fn keys that are supposed to control brightness don't work properly. When I use these...
Try going to control panel, then device manager, and try right clicking and updating all drivers that have to do with graphics or your screen. If this doesn't do the trick then try finding the display drivers manually.
MONITOR VT17N71, SN C0542C0739 I CANNOT GET THE RESOLUTION THAT I THINK THE SCREEN SHOULD HAVE. I'VE TRIED ADJUSTING THE BRIGHTNESS...BUT IT'S ALWAYS TOO BRIGHT. I'VE TRIED ADJUSTING THE CONTRAST,...
Hi.
Just a general suggestion.
Are the graphics drivers loaded.
(Assuming you are using Windows) what happens when you rightclick on the desktop screen and you click on the Settings Tab
When i try to graph something on my TI-83 Plus, the screen fades to pitch black and then it says INVALID DIM
Reset the RAM to clear old settings that interfer with your new problem
[2nd][MEM][7:Reset][1:All Ram][2:Reset][ENTER].
Press [CLEAR] to clear the screen.
After a memory reset you may have to adjust screen contrast.
To increase contrast (darken the screen)
1. Press [2nd] key and release it.
2. Press [UpArrow] key and release it.
3. Repeat sequence until screen darkens enough.
To lighten the screen
2. Press [DownArrow] key and release it.
3. Repeat sequence until screen lightens enough.
Hope it helps.
Brightness/Contrast Adjustment
try going to the setup screen button left of adjustments
try going to the set up menu on the left of the buttons come down to the slider control just above the information icon then go across to color reset hope this helps regards Jim
1helpful
Screen Contrast
On, your keyboard, there is the FN key in blue. hold it and go over to the four arrows pointing. up,down,left and right. the top and bottom arrows is what you use to change your comeputer's contrast.
Adjust screen Contrast
<Fn> +
Contrast up Increases the screen Contrast
<Fn> +
Contrast
down
Decreases the screen Contrast.
This will help you achieve this adjustment.
Top The Computers & Internet Experts
nexrad_chris
A Kisling
A Kisling
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
