Televison & Video Logo
Does model no, LCDVD2471A not have a eject button to get out my dvd on my television.I have looked all over the back and on the remote control.
Posted by Darlene Griffin on
SHAHEBAJ RIYAJ SHEKH
  • 3 Answers
Do it Manually
Posted on Apr 17, 2021
2answers
Where is. My eject button located on model.LCDVD2471A can't get my dvd out.
There are several times when the Disc tray in DVD players gets stuck and the assigned button does not function. It happens because of the following reasons :
? Dust Accumulation in the tray over a period of time
? Some mechanical linkage issue or system problem
In either case above, I recommend you to take out the tray out of the DVD player manually.
For more information click on the following link:
Ojooo Wad
Watch advertisements and receive the Bonus-per-View: With Ojooo, users can decide when and which advertisements they are watching and earn money at the same time.
For more information click on the following link;
https://wad.ojooo.com/register.php?ref=tlotlo.labane
1helpful
My tv has built in DVD player Sanyo ModelDP26671 and I can not get it to reject the DVD
Unplug the power cord, wait ten minutes and plug it back in. They try to use the eject button on the front of the TV, not the remote control. If this doesn't work, you will have to disassemble the cover of the base and help it out with you hand while an assistant presses the eject button.
2answers
How do I eject a DVD from a Sandstrom television
http://knowhow.com/article.dhtml?articleReference=636&country=uk
Cannot eject dvd from toshiba rc-1900 - remote control is working
I have same problem, the remote does not appear to have a DVD eject, despite having controls for the inbuilt DVD player. There is a button on the tv at the top left hand side, if this is pressed a couple of times in quick succession, the disc will eject.
Cannot find eject button or what to use to eject DVD from bauhn atv-32hdc1n. Lost the manual first time to use DVD and now cannot get it out. Hope you can help
On page v of the manual (if you had one), under the heading "DVD Mode", the first item in the list is an up-arrow symbol, with "Press to eject the disc" next to it.
That's simple enough, IF you have a user guide. But if you don't, and you weren't familiar with standard symbology for these types of buttons, you would be stumped by the moronic design of the remote control.
The up-arrow button is on the top row of the Remote Control buttons, next to the red Standby button. It's a standard Eject symbol, but not only did they just assume you'd know that, they obfuscated the situation further by marking it as "TV/Radio". So if you weren't familiar with the symbology, you certainly wouldn't be looking for something marked TV/Radio to eject a DVD.
But there's another catch: The up-arrow/eject button will only work if your Source is set to DVD. If for any reason you switched away from the DVD before wanting to eject it, you would find that the Eject button no longer works. You have to switch back to Source = DVD, then press the eject button.
IMO, there is no excuse for a Remote Control design that can't be figured out without the manual.
I have a sylvania model LD320ssx. How do I eject the dvd if I don't have a remote?
Unless it has an eject button on the unit you need the original remote.
2helpful
How to eject dvd
Someone needs to look inside to see if something got inside and is stopping the mechanism from working---I have even seen a few which someone had managed to get 2 discs in at same time.
If the mechanism is damaged it may not be worth repair as the DVD portion (if even available) costs too much.
1helpful
How do i eject a dvd from my newly purchased technika 32" flat screen tv there is no button on the remote control
If you can give me the model number for your television then I should be able to answer your question. If there is not an "eject" button on the remote then I would suspect there is an "eject" button on the TV itself where the other buttons are located or near the dvd player.
My remote control for my rca combo 20f510td is not ejecting my dvd from the t.v. .... also actually none of the dvd buttons are doing much of anything when I press them, i.e. the play, pause, eject,...
For remote control concerns. You can try to reset your remote control but be shure before you reset your remote your tv should be unplugged from the power outlet. So here are the 4 steps to reset your remote:
1. remove the batteries,
2. press and hold the number 1 button of the remote control, thus draining all the remaining electricity.
3. put the batteries back in.
4. plug the tv on the power outlet then turn the tv on and try the remote control.
Now if these steps do not work check the warranty of the tv and have your remote be replaced if it's under warranty and if not you can try to purchase a universal remote control that supports RCA tv's.
Top Televison & Video Experts
Marvin
Marvin
Lawrence Oravetz
