Televison & Video Logo
Question about Panasonic Televison & Video
Yesterday, after I turned on my 8-year-old Panasonic TC-L47E50 LCD TV, it started turning off and on by itself. Would you please help me fix it? Thanks a lot!
Both video and audio seem fine when it's on, but I cannot change input source. It's now always on HDMI2 which was the input (Comcast TV tuner box) when it was working the day before yesterday. It turns on and off with a sort of rhythm, 7-8 seconds on then 7-8 seconds off. I have to unplug the power cord to turn it off completely. When I plug in the power cord again, it doesn't turn on by itself, I have to press the power button, sometimes even twice to turn it on. Then it starts turning itself off and on again. I removed all the remote controls from the room to make sure it wasn't caused by bad remotes.
Posted by Bing on
ray gallant
    Top Expert:
  • Panasonic Master
  • 74,163 Answers
A good tv repair shop is needed by you
Posted on Apr 15, 2021
5 Related Answers
Anonymous
  • 68 Answers
SOURCE: f32650/atc113ca1
This could cause a problem, because modern TVs and most other entertainment electronic goods, have a small kind of computer chip, but there should be a Reset button probably inside the set! If you feel confident about computer chips you may be able to find the button by tracing the circuit.(Disconnected from the mains). Another idea is if there is a small button cell or battery inside, then try disconnecting it for a day. Good Luck!
Posted on Dec 02, 2006
MicrowaveSvc
William Miller
  • 9179 Answers
SOURCE: Jenn-Air Microwave M169B 11 years old.
You should be able to get a replacement keypad, and that's not a hard job for a DIYer.
If you're interested, post your correct brand and model and I'll give you a more specific suggestion.
(Your post subject says Jenn-Air M169B put it's posted under Sharp R-316FS so I'm not sure which you have).
If it's a Jenn-Air, you can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
You can usually find Sharp exploded views by entering your FULL model number here: http://www3.sears.com (the 3 is correct)
You can order Sharp parts from there or from Tritronics at http://www.wehaveparts.com
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jan 21, 2008
Anonymous
  • 67 Answers
SOURCE: Volume decreases by itself
maybe defective speaker or audio output ic or shorted capacitor within audio circuit
Posted on Nov 09, 2008
marionbagget
  • 718 Answers
SOURCE: Panasonic 32 inch LCD TV will not turn on-red light flashing
The number of flashes is an error code. Count the number of flash. It looks like one of the boards in your set is failing intermittently. Panasonic codes for a guide as a starting point. Exact board STILL has to be verified;
One Blink: One blink of the power LED indicates a problem in the inverter circuit located on the LCD panel. The inverter board is not to be repaired in the field. Therefore a replacement is required.
Three Blinks: Three blinks of the power LED indicates an over-current or over-voltage condition in one of the DC supplies of the AP board. The AP board is repairable. Therefore the use of an ohmmeter and peak-hold-voltmeter is required to determine the cause of the shutdown. An over-voltage condition is definitely a defect of the AP board. An over-current condition may be due to a short circuit located in the AP board, A board, or the LCD panel.
Five, Seven, or Eight Blinks: The A board is responsible for five, seven or eight blinks of the power LED. The MAIN +3.3V, MAIN +5V, and MAIN +9V sources are all produced on the A board. The detection input pins of the MPU, IC1100, monitor for their presence.
Four or Six Blinks: The AP board is responsible for four or six blinks of the power LED. The DTV9V, and SUB_5V sources are produced on the AP board. The MPU IC1100 monitors for their presence when the unit is connected to AC Power. A short or open circuit on the A board may also be responsible for their absence.
Nine Blinks: Nine blinks of the power LED is due a short circuit in the audio output circuit (s) of the unit. The audio output circuit is located on the A board. Confirm the status of the speakers. If defective, perform a replacement. If ok, replace the A board.
Ten Blinks: Ten blinks of the power LED indicates a malfunction of IC4200, the frame converter. This IC resides on the A board. Therefore ten blinks of the power LED requires the replacement of the A board.
Posted on Feb 11, 2009
John Riley
  • 441 Answers
SOURCE: Apex Converter Box died
the unit is dead, if you contact apex they should send out a replacment for you
Posted on Jul 10, 2009
1helpful
Do I need a board and if so, which one
Both the main and power board could cause the issue you're facing, only way to know what one is measure the power supply voltages, if they're ok after it's been on awhile it's most likely the main board. One other thing I'd do is run firmware or software updates as this could cause the issue
??How to fix a PANASONIC PLASMA TC-P60UT50
Could be the SC, but also might be either the SU/ SD causing the SC to go into protect. Pretty easy to determine, if you look at the SU SD and see any holes or burn cracks that would be the problem. Let me know if this works or can help further.
Update the netflix app on a panasonic tv
This reqeires a firmware update to upgrade the app. The firmware is at the bottom of the page. SMART VIERA 47 Class E50 Series Full HD LED HDTV 46 9 Diag
I have a Panasonic LCD tv, model# TC-32LX70, S/N MY71420839, manufactured May 2007. The tv wouldn't turn on unless the power cord was unplugged and plugged back in for about 2 years. Then it
Fault with the main power supply regulator section circuit board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Plasma TV turns off by itself-won't sty on for
when i turn my 32 inch VIVIO plasma tv on it turns pff by itself. i want to know why this is happening
My panasonic 32 lcd tv tc-32lx60 will not turn off
Really sorry abou that. Here's the transcript.
http://www.fixya.com/support/c36637
I have been posting responses all the way through. But you were not able to see them, possibly due to some kind of bug
LCD tv power light doesnot come on.
These off brand almost always have power supply issues that have to be troublshot. $150 at a local tv repair.
Top Panasonic Televison & Video Experts
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
