This is a commercial unit it error codes are different
Er 24
Boiler temperature probe Boiler temperature probe disconnected or not working malfunction
this is in the user manual
Testimonial: "thank you for you help,it was the sensor ,where can i download a service manual for the parameters.cheers."
That isn't a Smeg Error code. Are you sure it isn't E4?
CODE: E4
PROBLEM: Faulty Temperature Sensor
FIX: The temperature sensor monitors the temperature of the water in your dishwasher. Check the sensor itself and the wiring and connections to it and repair or replace as necessary.
https://www.google.com/search?q=smeg+cw511mdaus-2+error+24
I am Andrew as well Andrew :>)
Testimonial: "hi Andrew,it was a boiler tank sensor.error code 24.thanks for you reply.cheers"
