I can't believe that a Windows PC does not have an optical drive! You can download the software.
XL-550: Software ' SINGER Futura Support
https://futura-support.com > products > xl-550 > software
XL-550: Software. Version: Update version 4.0.0.6 for Windows XP; Windows Vista; Windows 7; Windows 8; Windows 8.1; Windows 10. Release Date: 01/02/ ...
XL-550 ' SINGER Futura Support
http://futura-support.com > products > xl-550
XL-550 · 215 Built-In Stitches Including: 6 Fully Automatic 1-Step Buttonholes and 1 Endless Buttonhole · Extra-Large Sewing Space - 210 mm · SwiftSmart™ ...
Softwares < Support - Singer Sewing Machine
https://www.singer.com.tr > support > softwares
SOFTWARES · FUTURA XL - 400 DRIVER · FUTURA XL - 400 WINDOWS 8 UPDATE · FUTURA XL - 420 DRIVER · FUTURA XL - 420 SETUP · FUTURA XL - 550
Posted on Apr 15, 2021
VAST Loptops had no CD/DVD drive.
it was an option on all old laptops.
just like wifi was, an option. too. then.
and now GONE.
on all.
w10 will run on a 2008 PC with no DVD.
no PC told by OP so no savvy answers
the full model number of the PC will contain, the code for DVD (ODD)
or if dell PC, the service tag tells you all things opted in or out of the PC day one new.
or has brand new Laptop and thin laptops
are too thin to have any CD drive.
cracker thin I call them. HP X360
there are 3 cures
get the software from the maker online
or copy the CD to USB thumb drive
using a real PC. with CD drive.
or buy the $15 USB ODD drive. best IMO.
always have one for days like this. $15 bucks.
SOURCE: I haven't cd with software
You can download the current versions of all (free) Nikon software from
http://support.nikontech.com/app/answers/detail/a_id/61
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use Nikon Transfer or any other photo cataloging program.
Posted on Jun 22, 2011
SOURCE: I need to know the
They say MUSIC or AUDIO on them. It's in the manual.
Posted on Jun 07, 2011
SOURCE: hi i have a western digital wd1600 160gb hard
Have you tried setting the jumpers on the new drive to CS (cable select) If you use that setting, the position of the drive on the cable determines whether it is master or slave. For example, the plug at theend of the IDE cable is the master and the plug in the middle of the cable would be slave. Just a suggestion. If you are using SATA, this does not apply.
Posted on Aug 18, 2010
SOURCE: I have lost my cd to download to another computer
The easy solution is to buy a small "card reader" that you stick your card in and then insert in a USB port to read it. You can check the site for drivers in their support section if you still want to use a cable.
Posted on Jul 02, 2010
SOURCE: i have a vivitar 5
You can download here
http://www.vivitar.com/ecms.aspx/67edf844-9613-4598-87e9-f5c2973ad54b/SupportFiles/DVR-550.pdf
and here
http://www.vivitar.com/ecms.aspx/aaab69a6-b31f-41aa-9fad-34c2bd1016b0/SupportFiles/Setup.exe
Posted on Apr 24, 2008
what is it, this XL-550
google shows vast things made with the model, I can not see it nor guess what it is or what it does or makers name;.
scale, or sewing machine or welder.
It must be a toy that is USB connected or something that has CD
a talking digital bathroom scale?
if yes have friend with real PC and read the CD and copy it to uSB thumbdrive.
then using that load the software.
or is a Singer sewing machine
ok I give up , and is not failing PC
and no PC told at all nor OS you run
so I do give up.
learn to google
learn to google makers name + model + support.
and find your own software from the maker.
SInger (wild guess this) is it?
SEWING?
https://www.futura-support.com/products/...
buy $15 cd/dvd external USB drive cheap
ebay.com or amazon.com. or any where that sells them.
not be helpless?
some things like this have COA license keys to run the software, so the CD may be super important if true.
