Trying to access the infinity switch for top burner. Removed all screws, but the panel remains firmly in place.
SOURCE: whirlpool electric range burner power light stays on but no heat
Hello givemeanidth.
Welcome to Fixya
You said, have a Whirlpool electric range (model rf363pxpt0) with standalone
burners - the burner power indicator light stays lit whether the heat
control knob is on or off, there is no heat coming from the burner on
or off. You pulled the burner from the receptacle and one of the tabs
broke off and stayed in the receptacle. You removed the tab and made sure
no pieces remained in the receptacle then bought a replacement burner,
no change. You put the replacement burner in the back burner of the same
size and had heat within 10 seconds. You changed out the burner with the
one that had been in the back of the range, no heat. As long as the
breaker to the range is on the power light stays lit but no power to
that one burner only.
What is the model number and the age of your range?
Waiting for your reply.
Huuum
Posted on Oct 03, 2008
SOURCE: kenmore glass top range left front large burner out
check the burner socket, it is likely that contact is being lost where the burner connects to the hardwired portion of the system (the socket). It is not unusual for the socket to "burn up" when there is a poor connection to the burner resulting in the burner being replaced and the new burner not working or working intermittently.
Please take the time to rate this solution
Posted on Jan 29, 2009
SOURCE: Whirlpool Range Stove Top Indicator Light Stays Lit
Hi, You will need to change the burner switch as well. It shorted out when the element went bad.
Please let me know if I can assist you with part # or anything else.
Vic
Posted on May 30, 2009
SOURCE: Kenmore C880 6587590 burner switch replacement.
I just replaced the switch just yesterday.First remove the glass panel by pushing back the 2 black clips at the top end,then remove 2 silver screws at the top and 3 at the bottom also remove 2 black screws behind side panels on the top. Now push side panels slightly up and forward and it fill fall forward and now replace the switch.
Posted on Aug 26, 2009
In order to test the surface burner on your electric range, the following steps should be taken:
An oven thermostat is a switch that opens and closes in response to the temperature
it senses. It is typically found in the control panel, where a
liquid-filled temperature-sensing bulb senses and maintains the internal
oven temperature by cycling heat on and off.
Adjusting the thermostat:
