Fills for 2 seconds, then stops
SOURCE: dishwasher stops after 10 minutes inlet/drain light flashing
I had the same problem on a 5 year old model. It was the main pump leaking from a perished seal causing the water protection microswitch to trip. This gives the symptoms you describe exactly. Parts cost from Miele was about £60 for a new seal. Fairly easy to fit.
SOURCE: outlet/inlet light flashing on miele dishwasher G674SC
Usually indicates a intake or drain fault - could be a plugged drain line at the garbage disposal or insufficient water coming into the unit
