BSOD and 0x00000116
The computer crashed with blue screen and 0x00000116 code. It occurred while I was playing a game
Posted by jamessteerforth on
  • Anonymous Apr 20, 2021
    google it, learn to, answered at MS like million times now.
ray gallant
    Top Expert:
  • Computers & ... Master
  • 72,232 Answers
Google it, learn to, answered at MS like million times now.
Posted on Apr 20, 2021
5 Related Answers
Anonymous
  • 186 Answers
SOURCE: crash dump blue screen
If warranty - call it in. Otherwise it sounds like a classic case of bad ram. Find a friend with similar ram in his/her laptop and do a test swap to see if symptoms repeat. Then replace the ram. Far more common in HP's then Toshiba, but it happens for no reason. Basically it's a page in or out error with the ram causing windows to "freak out".
You can get a good selection of ram from Tigerdirect.com or newegg.com.
Posted on Apr 28, 2008
Pyrhyc
Ryan Rogers
  • 2028 Answers
SOURCE: are there updates for my
A blue screen indicates an operating system error. Many times you can fix it by doing a system repair or reload, however, occasionally the blue screen is caused by a hard drive crash. To start you will need to run a system repair with your recovery or operating system disc. If the repair doesn't take, then try to totally reinstall the operating system. If you have any problems during or after the install then the hard drive has failed and will need replaced. If you have anymore questions feel free to ask.
Posted on Jul 22, 2008
asish_shrm
Asish Sharma
  • 121 Answers
SOURCE: turn on my computer works
Try to change the memory modules...if there is two inset 1 at a time and boot ur system to check if u still face the problem....if not try borrow a memory module..and check....it looks like its the memory in your case but if you u still have problem having verified that its not the memory...
First of all, you need to understand what "System32 corrupt or missing" actually means.
System32 is a vital part of your PC. You can look at it as the heart and brain of the Windows operating system without which, your computer would not be working at all. System32 is usually located in the C: drive under C:WindowsSystem32 or C:Winntsystem32 and is usually hidden in order to prevent any accidental alterations by the user.
Reboot your PC and press F8 during the booting sequence until you get into the boot menu. Select "Boot Using Last Known Good Configuration". Your PC will now try to startup using a configuration that has worked in the past. If you are still facing the System32 corrupt or missing error, you could try the following but you have to be careful. In case you are not comfortable messing with your system files, skip this part and continue reading the "Quick and Easy Fix" paragraph.
Use the Console to Fix the "System32 Corrupt or Missing" Error
Insert your Windows XP Recovery disk and reboot your PC. If you don't have a recovery disk skip this paragraph. Select the Recovery Console and type the following into the console.
This will recover your windows system but you need to be extremely careful that you are typing correct commands or everything gets even worse.
md tmp
copy C:windowssystem32configsystem C:windowstmpsystem.bak
delete C:windowssystem32configsystem
copy C:windowsrepairsystem C:windowssystem32configsystem
Quick and Easy Fix
In case you don't feel comfortable messing with your windows system; I suggest using a Windows System Repair tool which will scan your System and list all system errors before attempting to fix it. Besides solving the System32 corrupt or missing error, a system repair tool will ultimately speed up your System as it cleans and reorganizes your registry and deletes unnecessary files.
A commonly used tool is Errorsmart which is available for free at http://www.SpeedUpMyPc.Info Before re-installing windows or messing with your system, give Errorsmart a try and check if it is able to fix system32 corrupt or missing error
keep me posted
Posted on May 05, 2009
Anonymous
SOURCE: Sims 3 keeps crashing or BSOD "ati3duag.dll"
Go to the website for both the sound card and the video card. But you might already have the latest drivers, it may just be an issue with the game settings.
Posted on Nov 23, 2009
Anonymous
SOURCE: bsod problem due to reliance lxu 800 usb modem drivers
Hello dear, I'm one of the users of LXU 800 modem. I tried all the sources and found there is no way resolving this issue because the manufacturer has not yet released any updates till now. I also heard the team at Reliance doesn't care about this issue because the actual manufacturer is LG. Anything to share? Meet me at [email protected] Have a great day. Yours truly, N Bhargav Reddy.
Posted on May 12, 2010
BSOD on new computer
BSOD is not a good term to use. That term means that screen comes up WITH WHITE writing on it and it shows what the error was that caused the problem.. So if it is a true BSOD then what are the codes that show up?
Mar 19, 2018 | Dell Computers & Internet
What is RAID? Can this cause video issues? Can the Video problems be ralated to the PSU?
RAID is where you use data in stripes over many disks to improve reliability, one disk can go down and can be replaced without rebuilding machine. RAID is not appropriate for a single disk machine.
Jun 23, 2014 | Dell Dimension 8100 PC Desktop
I have a Logitech Quickcam Orbit AF which causes my computer to crash whenever I try to use video. My os is windows 7 ultimate. Any ideas? DHA
It is most likely the driver for your camera. Check the Logitech website for the most up-to-date drivers and install them.
The crash screen, otherwise known as the "Blue Screen Of Death" or BSOD, is usually caused by an error on the driver level. This can happen when code in the driver for the device conflicts with something in Windows or your computer hardware, and the system shuts down to prevent damage. The BSOD gives information about what conflict occurs, and creates a "dump" file with more detailed information.
There is a freeware utility you can download here that will analyze the dump and give you more information about what caused it.
Oct 30, 2013 | Logitech QuickCam Orbit AF Webcam
Stop: 0x00000116 (0x80c4c510, 0x8c106a30, 0x00000000, 0x00000002)
That is referring to a memory loop error caused from a corrupted driver. Boot your pc into safe mode and restore it to a date b4 the error started.
Aug 11, 2011 | HP Computers & Internet
My laptop sometimes malfunctions in the middle of a project and theres a blue screen that says duping of physical memory.i play a lot of games nd i dnt knw if thats whats causing the problems..i want to...
BSOD apppears because a program crashes. Fin out the error number on the BSOD, identify the program and uninstall it.
The games can cause that only if the BSOD happens when you're gaming.
In almost all of the laptops the video card is onboard and can't be replaced. In all the other cases the video cards are proprietary - that means that they have a custom shape and they will not be replaceable by any other ones. The extremely few that allow an upgrade are doing it with boards specifically made by their manufacturer of the laptop and they cost enormously.
Sorry, if you want better gaming performance then you will need a new laptop
Sep 12, 2010 | Computers & Internet
I keep getting the bsod while installing windows xp
loads1900
To be able to properly address your BSOD I will need some info from the BSOD. The link below will show you the info that I need.
http://www.fixya.com/support/r4443711-blue_screen_death_bsod_important_info
Thanks
Issken
Mar 29, 2010 | Acer Computers & Internet
Error Code 8001050F Trophy registration incomplete
Global issue, Seems Playstation network is offline(CRASHED). Your date and time are off too, and it wont allow you to update it via the internet. Your going to have to wait till Sony fixes it........
Mar 01, 2010 | Sony Playstation 3 (PS3) Console
Plugged in the 1TB WD My Book Essential into my Dell Dimension 3100 running windows xp and the screen goes blue and I get a error stating "Bad_Pool_Header"
here's a solution I found on google:
BSOD the Solution:
Did you install Service Pack 2? Are you now suffering from the Blue Screen of Death (BSOD)?. Here is the solution. I have spent 4 days hunting down the cause of my machine crashing and have finally cracked it. Maybe other people have a different cause than mine so my solution may not work for everyone.
After installing SP2 I suffered many crashes. In particular the Screen would turn blue and display a message starting "Bad_Pool_Header". And ending with STOP: 0X000000019....
Then my four day hunt for the cause started.
BSOD Solution
Basically I found two causes of the BSOD.
Cause 1: Corrupted file or folder.
Cause 2: Microsoft Indexing Service
Possibly these two causes are linked.
Solution for Cause 1
Onen up Explore (right click the start button), and expand your directory tree, starting from the C: drive. Click on each folder in turn and see if any cause the BSOD to appear. If so, reboot, and simply attempt to copy the folder, and then delete it.
Solution for Cause No 2
Switch off Microsoft's indexing service. You can do this by clicking the start button, select "Run", then type "msconfig", then select the "Services" TAB, scroll down to the Indexing Service and Switch it off. Reboot your computer, and good luck - maybe it will work, It solved the problem for me.
At first I thought I must have a third party software or hardware conflicting with SP2, but even after I had disconnected the internet, switched off all items in the startup TAB of msconfig, was still getting the BSOD. I tried surface scans, chkdsk, scan disk etc all to no avail. I tried defragmenting the disk, but the frequent crashes may have made things worse.
I discovered the computer was now crashing after about 7.5 minutes of being switched on. It did not matter whether anyone logged in or not.
Finally I went to msconfig (Start Run, MSCONFIG) and switched off "process System.ini files, Load System files, Load Startup Items. And the comuter stopped crashing. So then I added the item back one by one until I discovered the Microsoft Corporation Indexing Service which was causing the crash. I switched it off and switched everything else back on and AT LAST... No more BSOD
Jan 01, 2010 | Western Digital My Book Essential 1TB...
Computers & Internet Logo
k24674
