Televison & Video Logo
Question about Samsung Televison & Video
Samsung led 65 inch left side of screen is a 5 inch wide white vertical strip. can anyone help me ?
Posted by Warren St Germaine on
Aron
    Top Expert:
  • Samsung Master
  • 2,375 Answers
The Vertical colored lines that usually do show up on TV screens is when the T-Con board is not working correctly and most times this can be simply be caused from wiring that is not securely or fully fastened. Other times the T-Con Board itself might be faulty and needs to be replaced.
Posted on Apr 15, 2021
5 Related Answers
Anonymous
SOURCE: White vertical line on left side of screen
I had a smililar problem after taking it apart i realised that i had screwed my mount skrews into the video main board and cracked it along with a few soldered wires, if you havent done any physical dammage to it try a firmware upgrade
Posted on Mar 06, 2008
Anonymous
  • 563 Answers
Hi there
This problem can only be fixed properly by replacing the Mainboard.
Posted on Apr 01, 2008
Anonymous
  • 146 Answers
SOURCE: Samsung 52 Inch LCD 120hz. 3 inch wide vertical line on screen
This is a problem with the LCD panel. If the tv is out of warranty, I would call Samsung and see if they will pay for the panel and you pay for the labor. The panel is not cost effective to repair. If Samsung will not do anything you will need to buy a new tv.
Posted on Nov 17, 2008
chadande
  • 12 Answers
SOURCE: VERTICAL WHITE BAR ACROSS THE LCD SCREEN
Almost certainly the LCD panel has failed, and would be replaced by Dell if it is still under warranty. You can try to replace the VGA or DVI cable that connects the LCD to the PC. If the problem persists it is the LCD.
Posted on Mar 18, 2009
Anonymous
  • 2229 Answers
SOURCE: Got white vertical lines on left side of display
Vertical lines on an LCD screen are not a good sign. This usually means that your screen is going bad.
Posted on Jul 21, 2010
TV dim on right side with vertical black line
The screen and the LCD are broken and are going bad and should be replaced for your TV and the ribbon might also be damaged too and needing to be replaced.
PN59D7000 samsung plasma - bottom 1/5 (approx) went white along with a vertical black bar, a couple inches wide, just to the right of middle. Does this look like a Y main board (maybe buffers too)?
It has two problems one with a buffer card. , and another with the drive left . , to do a test with the drive , and disconnect if it turns white , it's just the card drive , but is screen
There is a vertical black bar along the left side of my TV. It started as a thin yellow/white bar and has grown to be about 2 or 3 inches wide, blocking that portion of the screen.
The LCD wafer has gone bad, and more lines will begin to appear over time. It can be replaced but the cost may be comparable to replacing the entire television.
B&w 6800 lots of horizontal black line areas. also, a vertical white strip about 3/4 inch wide about 3 inches from left side of paper
Hi!
the best thing is to make a copy using the glass and not the document feeder!If there is no lines on the copy simply lift up the cover and on the left side of the glass will be a thin strip of glass,Clean it with a dampened cloth and all line and marks should be gone1
Good Luck!
1helpful
Strips of 2 inch wide black and white, running top to bottom
Definately a damaged screen, no way to fix it for less than the cost of a replacement screen sorry.
Hi there
Marvin
Marvin
