Washing Machines Logo
Question about Maytag Washing Machines
Neptune MAD21PDDWW coin operated. Why isn't it registering quarters deposited?
No error codes. I've replaced the coin drop sensor and still not working. Washer works in free mode
Posted by Ely Van Egmond on
ray gallant
    Top Expert:
  • Maytag Master
  • 74,163 Answers
Call your repair man we do not know here
Posted on Apr 16, 2021
5 Related Answers
Anonymous
  • 525 Answers
SOURCE: Error code PF
PF means Power Failure!
Unplug both units for 10 minutes, then plug them back in and try operating them. You may need an electrician to investigate why you are losing power to both units
Posted on Jun 04, 2008
Anonymous
SOURCE: What does error code Lr mean and how do I fix it?
http://www.bobvila.com/wwwboard/messages/155863.html
says:
just an FYI to anyone who might need to know. my neptune started kicking up an error of LR and stopping. i ended up sending an email to maytag and got a response back from one of their techs. the LR code means "Locked Rotor". when this happens the cause is one of two items. 1) the circuit board at the top of the unit has lost connection to the motor and its control board at the bottom (connector loose) or 2) the motor and or control board at the bottom have trashed and need to be replaced (P/N 12002039).
hope the info helps someone as i had a heck of a time finding it.
Posted on Jan 14, 2009
Anonymous
SOURCE: Maytag Neptune Error COde "nd"
I had the exact same problem. nd code (no-drain) at the end of the cycle and when I opened the door the machine was still full of water. I took the back panel off the washer and disconnected the drain hose from the pump. (You're going to get quite a bit of water gushing out at you so be prepared with towels or a shop vac.) At this point you should see a little rubber disc over the end of the section you just exposed on the pump. This is a little drain flap. Just lift it up and you should be able to see into the pump a little bit. At this point I poked around in there with my finger and found a hair pin stuck in the pump! I wasn't able to get it out from this end of the pump so I disconnected the big rubber boot which connects the wash drum to the pump. Then I was able to twist the pump (counter clock-wise) and release it from the washer base. I didn't have to disconnect any wires and was then able to see into the other side of the pump and pull the hairpin out. Put everything back together and it's worked fine ever since. I've never even looked inside a washing machine before but it really was really fairly simple. Now my husband really does think I'm a domestic Goddess. I said he should take me out to dinner with the money we saved on a service call!!
Posted on Mar 18, 2009
Anonymous
This is now the 3rd time this has happened. The 1st 2 times it cost me ~$100 to have a technician come in and fix.
This time, I did it easily. For my Maytag Neptune washer, I removed the back panel (2 screws). On the bottom tray is the water discharge pump. On the output side of the pump there is a small cavity under the rubber flapper where a nickle fits perfectly. I removed the nickle, reattached the output drain line. started it up ...
and viola! the problem solved.
Posted on Jun 28, 2009
Anonymous
  • 232 Answers
SOURCE: Maytag Neptune rinse cycle doesn't start.
cold water valve screen plugged or bad valve, just check it!
Posted on Aug 02, 2009
How to get coin operated washer to stop eating quarters
you need to alert the owner of the machine to fix it and get your money back
1helpful
Change the price on maytag top loading washer
Price change for a model MAT12.
Remove the access plate above the coin acceptor with a key. The display should show code 6 and two numbers. Code 6 is the regular cycle and the number of coins required to start. Press the perm press button to advance the number of coins. 06 equals 6 quarters, 08 equals 8 quarters, etc.
Reinstall the access door when finished.
Stephen
My washing keeps clicking locked and then unlocking. Took three times for it to start and it is making a noise I haven't heard before. We bought it 7 1/2 years ago. I take good care of it. Now the it...
Hello there and thank you for choosing fixya
Ahhh, the ND error code on a digital Neptune front load washer. The ND code means 'No Drain' and it is probably just something caught in the pump. I've seen where a coin can get in there and keep the pump from starting.
Some other items known to stop a Neptune pump: Rubber backing from a rug, rubber bands, bobbie pin, lens from a flashlight, tooth pick and a bra wire. Maybe you had something different in your pump?
If you have a floor drain you should be able to drop the discharge hose to the floor and let gravity pull the water out so you can take the pump out and get a good look at it.
Also a word of advice to avoid wasting time. The pump is usually towards the front of the machine. ok?
Hope this is very helpful for you
Best regards Mike
Code on MAH9700 display is ND- clothes are sitting in water.
Some other items known to stop a Neptune pump: rubber backing from a rug, rubber bands, bobbie pin, lens from a flashlight, tooth pick and a bra wire. Maybe you had something different in your pump? If so, please comment with what you discovered in your pump.
Hope this helps.
Wont cycle get ND error message
The ND code means 'No Drain' and it is probably just something caught in the pump. I’ve seen where a coin can get in there and keep the pump from starting.
Some other items known to stop a Neptune pump: Rubber backing from a rug, rubber bands, bobbie pin, lens from a flashlight, tooth pick and a bra wire. Maybe you had something different in your pump? If so, please comment with what you discovered in your pump...
Change the number of coins to operate
you need to take the coin slot apart take pictures as you go to put back together the parts to change amount are hidden inside it in hidden compartment if they wheren't removed by some one. your machine didn't come with the coin mech so if you don't have the parts you will need to take it with you to the parts house to get right parts. open the top of the coin mech box there are 2 long rod screws holding it in place usually 5/16 inch wrench fits may need to wiggle the heck out of it to get it out
We have a maytag neptune washer and on evey setting, it's telling us d5 - what does it mean?
D5 means blocked coin 1 or coin drop control circuit failure, coin recognition and price display disabled while blockage persists.
3helpful
2answers
Error code d5 on front load neptune washer
d5 is a door lock error code,more than likely a bad door latch it's an easy repair,here is a link to the Neptune repair manual this the Mah 3000 but they all come apart the same way the only real difference was in the control panel and the door latch in yours uses a solenoid to lock instead of a wax motor
http://www.applianceblog.com/manuals/MaytagNeptunenew.pdf
Offshore looking for Manual for: Dryer: MLE19PNDYW Washer: MHW1919XXAWW They are the stackable Maytag Combo....we have 4 of them. The operation manual would be best, but the biggest delima is...
jljbf,
You said,
Dryer: MLE19PNDYW
They are the stackable Maytag Combo....we have 4 of them. The operation manual would be best, but the biggest delima is getting the sensor off for the coin deposit....
Please help!
Here is a fixya.com sponsor that can get you a manual
http://www.servicemanuals.net/?gclid=CPn144D54ZUCFQNfFQodLTkgeQ
Bless You,
Please give me a solved rating before you sign off.
Thank You
Top Maytag Washing Machines Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Steve
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
