Washing Machines Logo
Question about Amana Washing Machines
Tansem 7300 front loader. Which side should I lay it on to replace pedestal?
Posted by Tony Peak on
ray gallant
    Top Expert:
  • Amana Master
  • 74,163 Answers
5 Related Answers
Anonymous
SOURCE: washing machine belt replacement
The repair sounds worse than it is.
2 hose clamps
4 big bolts
3 torx screws
a little wiggling and viola!
hints: take a good look (or digital pix) of the belt before you remove the pump, keep a few large towels around to handle the water in the hoses and to cover the front edge of the machaine to make it more comfortable when you're removing and installing the motor, the connector has a latch you have to press while removing the cable, the mounts for the motor frame/pump assy. need to be sprung out a bit when reinstalling.
Comment: the shaft from the motor is "double-D" shaped and slips into a plastic fitting in the middle of the pump. I don't see how you can break the pump unless you drop the motor assy on it...
Kudos to "sir fixalot" for giving me the courage to rip in to it...
Posted on Mar 05, 2008
Anonymous
SOURCE: Fridgidaire FTF2140ES0 Front Load Washing Machine Vibration
Try going to GVIINC.net - there product definately works.
Posted on Jan 14, 2009
Anonymous
  • 360 Answers
SOURCE: I have front loading washer/dryer;need to install pedestals.
Yes!!!! Do not lay the machines on their backs with out the shipping bolts/hardware installed..Major damage will occur!!!!!
clarkco
Posted on Feb 28, 2009
Anonymous
  • 71 Answers
SOURCE: My Amana washing machine stopped spinning.
moz-screenshot.pngac4805b.gifhere is the image on how to change the belt......it's pretty easy to do as you can see by the diagram.PS2027742 is the part number on the belt.
Posted on Oct 03, 2009
richroth
Richard Roth
  • 9472 Answers
SOURCE: amana tandem 7300 stopped ,door is locked wash
Door won't unlock
Did all of the water drain out of the washer during the spin? Select DRAIN & SPIN to remove any water remaining in the washer. The washer door will unlock at the end of the drain.
Is the door locked and is the "Add Garment" light on? Press START/PAUSE once. The door will unlock.
Posted on Nov 28, 2010
How to replace the thermistor on lg front loader washer model WM24887HWM.
There are two thermistors. The one most likely the issue is the one one the bottom of the outer drum. Videos on YouTube or repairclinic.com or appliancepartspros.com will show takintop off, taking control panel off, then finally taking front of washer off. Then very easy to replace gat pesky $6 part. If you are slightly dexterous, you can turn washer on it's side(if you don't have a pedestal), and replace the thermistor directly by reaching around a bit. Good luck.
Just purchased a LG 8500HSA Mega Front Load Washer Special Order! What is the Pedestal Model Number?
Please check your model number. 8500HSA does not cross to anything on LG.COM.
Universal pedestals are for sale at Sears, Home Depot, Lowers, and Best Buy. The pedestal and machine will bolt together, that is, a bolt will run upward from the pedestal into threaded bolt holes in the bottom of the washer. If you can measure the distance from bolt hole to bolt hole on the bottom of the washer, you can check to see if the universal pedestal fits before you buy it.
Several months ago I took my front loaders off the pedestals. The pedestals were kind of nice for handling the clothes but about 40% of the time I spilled either detergent, bleach, or softener because the pedestal put the drawer too high for me.
Amana washer, how do you replace belt
front loader from the back, top loader from bottom by laying it on the side
1helpful
I need to change the belt on front loader amana tandem 7300
The back doesn't come off - the 'shell' (top and sides) come off. Then you should be able to get to belt from the side, you'll need a lot of room to work with it.
1helpful
My washer jumps around when spinning. this happens intermittently
if it is a front loader and on a pedestal make sure it is level not just front to back but side to side also. Here are some of the reasons a front loader shakes violently.
1-- not level
2-- unbalanced load... washing 1 item or large comforter
3-- Wrong soap.. using reg detergent instead of HE
4-- bolts mounting mach to pedestal are loose. They are located above the drawer. two for front and two for rear.
5-- Faulty shocks.. requires tech to repair
6-- unhooked springs.. requires tech to diag and repair
7-- rear bearing failure. can be checked by pushing up on top front edge of basket and looking for movement independent of outter tub. Sometimes you can feel a clicking of the bearing moving up and down when you do this. This repair usually costs more than the machine is worth if very old. Ignoring this problem can lead to more damage, water leakage, and possibly fire.
WHERE CAN I FIND PEDESTALS FOR MAYTAG NEPTUNE WASHER AND DRYER MODELS MD55 AND MAH-1 MODELS?
Don't...Unless you have a concrete floor you will never be satisfied with the pedestal. Your front loader will shake a lot more. People buy these things then I go to there house with a "shaking" problem and then they get mad at me because I tell them it's because of the pedestal. Front loaders were designed on concrete floors so they're only going to work like they say on concrete floors. Do a little research before you make that decision please. Not to mention they're about 200 dollars or more. Just a heads up I don't mean to bring ya down.
Need new drawer leveling feet
goto Sears.com .. look under parts.. key model # if you have it..
1helpful
2answers
Attach washer to pedestal
there should be bolts that come with pedestal so you need to take your legs out of the washer now lay it on its back then bolt the pedestal up to it and if the pedestal dont have feet put the ones out of the washer on it
Whirlpool WHP1000SQ 10" Pedestal this came with no instruction where can i get on line instruction
if you want to put the pedstal on unit..lay unit on back.pull draw out of pedestal ,than lay pedestal on back then put the bolts or screws in though pedestal ,,and stand ...
10helpful
2answers
Remove washer pedestal drawer
I have a GE front loader on a pedestal & needed to remove the drawer. I got an answer from their website below. Basically, on this model, unscrew the hex-head screw at the FRONT of the side rails on each side.
http://products.geappliances.com/ApplProducts/Dispatcher?REQUEST=SPECPAGE&SKU=SBSD137HWW&SITEID=GEA&TABID=4 Manuals & Documentation tab - page 2
Open Questions:
Top Amana Washing Machines Experts
Mike
Virgil Watts
Marvin
Marvin
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
