Question about Brother Office Equipment & Supplies
How do I change the letter The cursor is on the small letter and I want a larger letter how do I get to it?size on my Brother PT 340 label maker? Please and thank you.
Posted by Donna Pitoniak on
ADMIN Andrew
    Top Expert:
  • Brother Master
  • 50,042 Answers
5 Related Answers
Anonymous
SOURCE: change cartridge Problem - Brother BRTPT65 P-Touch Model PT-65 Home and Hobby Label Maker Printer
Once you snap in the catridge you have to put the back of the p-touch back on. After that you can feed through the tape by pressing Code Space. If the back of your P-touch is not on it will not advance through.... I learned the hard way :) Hope it helps you all.
Posted on Dec 29, 2008
Anonymous
SOURCE: can't change the font style & size on my Brother PT-65 Label make
In case you've forgotten how to change the text size, hold down 'Code' and '& Size' key to display the current setting. While still holding the Code button, push and release the '&' key to change the size.
To reset, I would try removing the batteries for a few minutes before reinstalling them.
Just two guesses.
Posted on Jan 07, 2009
Anonymous
SOURCE: I'm trying to scan a ledger size document and it
Problem solved. I was doing the scan using the buttons on the copier/scanner, but you cannot set the scan size this way. You have to use the ScanSoft Paperport program on the computer.
Grizzly
Posted on Jun 05, 2009
Anonymous
  • 76 Answers
SOURCE: model PT-1900/1910 operational manual is lost.
I assume that you need the manual for your printer.
Here you can download:
http://www.ptouchdirect.com/ptouch/manual/PT1900.pdf
On page 26-28 it explains what you need to do to change the size of letters.
Posted on Apr 09, 2010
Anonymous
  • 268 Answers
SOURCE: brother p-touch model 1880 label
To change the font size, do the following:
1. Press the "Function" key
2. Press the "Left Arrow" or the "Right Arrow" key until the display shows "SIZE".
3. Press the "Function" or the "Return" key. The current selected size setting is displayed and a triangle indicator pointing a sample of the character size above the display.
4. Press the "Left Arrow" or the "Right Arrow" key until the desired Size is displayed.
* SIZE1 equals Standard Size.
* SIZE2 equals Double Width.
* SIZE3 equals Double Height.
* SIZE4 equals Double Width & Double Height.
* SIZE5 equals 4 x Width & Double Height.
* AUTO, the machine will automatically adjust the characters to the largest possible size according to the width of the tape installed in the machine.
Press the "Function" key or the "Return" key to select the characters size.
I hope this helps.
Posted on Aug 09, 2010
I Have a Brother ptouch 340 and I am typing a label and I would the letters larger but I don't know what keys on the keyboard to use Do I use font and what else?
To just change the font size, press and hold the Code button. Then press the 1 (! and Size) key several times until the desired character size is reached. Then release the Code key. See https://www.manualslib.com/manual/219240/Brother-P-Touch-Extra-Pt-320.html?page=29#manual . This works unless you are already using one of the Big fonts. However, the size of your label tape will limit the font sizes available. To change the font, press and hold Code and then press Font until you get the desired font. Release the Code key at this point.
I hope this helps.
PT 1280 suddently printing miniscule letters. Can't reset, have turned off using Shift/clear buttons, but doesn't change after settings redone.
What size tape are you using? If you have switched from half-inch to quarter-inch tape, then chances are that the printer is working correctly as the general size of the print is determined by the size of the tape. Beyond that, you can use the Text button at the top-center of the keyboard to enter the options for customizing the print such as the font used, the size (small, medium, or large), the width of the letters, and the style (such as bold, outlined, or shaded).
How do I change the font size on Brothers label maker model #1290?
This is one of the most frustrating label makers I have ever used. VERY user Unfriendly.
3helpful
Model PT-1900/1910 operational manual is lost.
1helpful
2answers
Have Downloaded "instructions" for PT-1280.................
1. Your site and the search engine I used state "free" help - no plan or package mentioned.
2. My question was in regard to a PT-1280.
3. I simply asked if anyone knew how I could get the instructions for this label maker larger as the download has every thing squeezed on 2 pages with the type so small it can't even be read correctly without straining with a magnifier. It comes as a PDF file and cannot be cut - stretched or enhanced anyway that I know to do.
Thank you for your email asking if I would like find out about your plans. The questions I have would be related to my equipment I use at work and I am not even going to consider digging in my pocket for anything. The equipment I use at home is wireless and works excellently and as I stated originally I do everything - including labels and programming from my personal computer.
18helpful
5answers
Can't change the font style & size on my Brother PT-65 Label make
Just two guesses.
Brother PT 65 Label Maker
i've never been able to change the font. just sizes, and make it BOLD, Italic, underlined ect.
only one style font however
Changing size of lettering
1) Turn it on
2) Press function
3) Press the right facing arrow until 'size' appears on the screen
4) Press function again
5) Press the right or left facing arrow to make it smaller or larger
6) Once the small arrow on the screen is under the size you want press function again
6helpful
3answers
Brother Model Pt-65
There are two vertical fonts - small and normal. To put the labeler into vertical mode, hold down the [Code] key and tap the [J] key.
When it asks " 1-9 ", let go of the [Code] key.
Press the [8] key if you want small vertical type, OR the [9] key if you want normal size vertical type. Then you have to hit the [ <--' ] enter key.
Now you are stuck in Vertical mode ! :-O
To get back to normal, hold down the [Code] key and tap the [J] key, Let go of the [Code] key.
Then tap the [3] key and the enter [<--'] key. You are back to horizontal labelling.
:-) phew!
Gary
Gary
David Shaub
