Computers & Internet Logo
Question about The Computers & Internet
My imageBox 9mp standalone is plugged in, starts up for a second then turns blank while it's trying to read the scan disc. Nothing shows after. How do we fix this?
Posted by Kenneth Felsburg on
  • 1 more comment
  • Anonymous Apr 13, 2021
    Pacific Image ImageBox 9MP ST for Windows and Mac (STAND ALONE BOX,)
    IT IS A DIRECT PHOTO SCANNER EVEN DOES 35MM SLIDES.
    CAN SCAN TO sd card too.
    and to a PC via USB and matching software on that end.
    you are saying the local LCD display goes dead. at turn on.
    IT is 10 years old.
    using the wrong AC power pack to it?
    on the rear are 3 ports
    USB
    AV TV port and power
    if the power pack is bad or using the wrong one, (gee I have like 50 here and all are labeled to usage.) mixing that up invites blowing up the scanner.
    google is hard, rare device
    AC 100V - 240V / OUTPUT: 5V DC
    see some have this.. guess 1 amp.
    use the word Pacific image or get no hits.
    use real names, of things not just model.
    if that is true and you stuff in 12v or even 19vdc, you wrecked the box.
    never mix up powerpacks or pain.
  • Larry Ng
    Larry Ng Apr 13, 2021
    ok one guy sells this on ebay
    manual there and photo of page on ac pack
    5vdc, 1 amp so now you know.
    PACKS FAIL ALL THE TIME, NOTHING NEW THERE.
  • Anonymous Apr 14, 2021
    it's bad get it fixed (a shop)
    AC power pack bad
    PCB power board inside bad
    LCD screen inside bad.
    and more, inside.
    nobody can guess what,but power pack dead, weak or wrong one tops my list.
    common that.
ray gallant
    Top Expert:
  • The Master
  • 74,163 Answers
  • Anonymous Apr 13, 2021Pacific Image ImageBox 9MP ST for Windows and Mac (STAND ALONE BOX,)
    IT is 10 years old.
    USB
  • Larry Ng Apr 13, 2021
Ask for more information
Posted on Apr 14, 2021
5 Related Answers
Anonymous
  • 239 Answers
SOURCE: start up problem
It sounds like your Hard Drive may have went bad, My dell C640 did the exact same thing, I was able to get it to work a couple of times by taking it out and shaking it a little its kinda hit and miss if you can get it to work that way, But if you can save all your files to a storage device right away so you don't loose it all, and thats if you can even get it to fire up for you. I am almost positive thats the problem. You can get a new one from the manufacture or off ebay. Hope that solves you problem, The reason it won't boot off the install disk is the hard drive is not working anymore, Alright take care If you need help finding or how to write me back
Posted on Dec 22, 2007
Anonymous
  • 416 Answers
SOURCE: Disc driver not reading discs
Can be several reasons
1. Disk is upside down
2. Lens is durty. Use CD/DVD cleaning disk
3. Disk is recorded in higher speed than your driver can read (for instance reading speed is 16, but disk is recorded on 24).
4. DVD drive is damaged or not connected properly.
Good Luck
Posted on Dec 13, 2008
Anonymous
SOURCE: Goes through motions of scanning normally, but shows blank page
Epson PERFECTION 1670 AC Adapter driver download
Posted on Jan 23, 2009
Anonymous
  • 3600 Answers
SOURCE: CDR shows No Disc
Have you tried to use a optical disk cleaner? it will remove dirt from the optical eye and is the first thing I would try. Since it won't read any disks then the optical eye may be dirty you can buy at Radio Shack, Staples, Office supply stores and Wall mart or Wallgreens Pharmacy you can order online at fry's or tiger direct.com hope this helps, if you need more help just post here.
Posted on Jul 10, 2009
Anonymous
  • 80 Answers
SOURCE: How can I record a tv show onto a blank disc? I
Make sure you have the right DVD disc and the disc is clean if you do... (2) make sure you connected it right and are fully seated. LINE IN on your DVD-R is for the recorder part LINE OUT on the tv is to send it to the DVD-R If you done that try another RCA cable or two That should fix it
Posted on Jul 15, 2009
2answers
I cannot get the scanner to turn on
is the green led light on in the front panel?
When i turn on my wii it shows a blank screen
do you have it plugged in to the tv? if it is, for some reason red Wiis don't like to work. Mine doesn't read most discs
Cdr is not reading blank disc shows disc error
A few small things to try. Turn off unit, unplug for 5 minutes, plug back in, turn unit on.
There is a product called a cd/dvd lens cleaning disc. Worth the investment to have around.
Sometimes spindle dvd blanks have a few bad ones.
Check manual, might describe exactly what types of dvd blanks are best to use with the unit.
Just some suggestions, hope this helps.
Screen is blank? can you check this computeR? exentsa acer model #jalao
If your system seems to be going through its normal boot routine, look at the screen from several different angles. If you see 'ghosting' then it is likely the display backlight or the inverter for it that has failed. If you have, or can borrow, a standalone monitor, plug it into the VGA port of your notebook. If you still see nothing, it may be only that the external port must be turned on in your CMOS setup but the external monitor should at least show text during the boot routine.
2answers
2helpful
2answers
My ps3 wont read any disc game or blue ray dosent show icon
looks like the disc drive driver issue ... not recognizing the disc drive... remember that the playstation is a computer. When troubleshooting the Sony treat it as a computer. Might need to replace the disc drive.
Won't accept any dvd disc
It sounds like the Laser went out. Buy a new dvd player
Dvd re-writer will not read any blank discs
if you have nothing on the cd then it won't read it cause there is nothing for it to read... so if you have a writing software that you can write the cd you can write the cd... only if there is something on the cd it will read......
Top The Computers & Internet Experts
NADARK
NADARK
A Kisling
A Kisling
nexrad_chris
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
