All lights on fans running just. No heat.
SOURCE: oven not heating
You need to replace the fan oven element.
access to it is by removing the rear panel in the oven, there you will see the element.
Plz rate my solution.
Thanks.
Posted on Dec 18, 2008
SOURCE: fan oven wont heat up
If fan is workintg, but no heat, then replace oven element.
If no heat or fan, then make sure timer is set on manual and not on auto
Please rate my solution.
Thanks.
Posted on Jul 01, 2009
SOURCE: indesit fde20 main oven wont heat up
sounds like the circular element at the back of oven has blown.
Posted on Oct 24, 2009
SOURCE: oven not heating up [fan works]
It wilbe a faulty oven element, you will need ti fit a new one.
It is located at the rear of the oven, behind a removeable cover.
Thankyou.
Posted on Feb 11, 2010
No grill or.oven heat
Should say light on inside and fans run no light on front panel.just clock
