Ovens Logo
Question about Belling Ovens
Belling oven wont heat on any setting - Belling Ovens
Posted by Jonathan on
ADMIN Andrew
    Top Expert:
  • Belling Master
  • 52,944 Answers
Check if the timer is set? If that is okay, a failed element is the most likely cause. Disconnect the leads and check continuity with a test meter.
Belling Oven is Not Heating Up You can test whether your Belling oven is heating up correctly by turning the oven on, setting the temperature and letting it sit for five minutes. If the oven cavity is not hot when you open the door, it is likely that your oven element is broken.
Belling Oven Not Working? Here's How To Fix it
Posted on Apr 13, 2021
5 Related Answers
Anonymous
SOURCE: belling synergie. oven
if its flashing auto.
Press and hold the 2 buttons on the left hand - clock and cook time and then press the + button.
This then sets the time to allow manual and takes the auto off.
cheers
will
Posted on Aug 19, 2008
barkencoa
Barry Coates
  • 3463 Answers
SOURCE: Cooker is a Belling XOU270 / XOU271
You need to replace the fan oven element.
Posted on Dec 16, 2008
barkencoa
Barry Coates
  • 3463 Answers
SOURCE: fan oven wont heat up
If fan is workintg, but no heat, then replace oven element.
If no heat or fan, then make sure timer is set on manual and not on auto
Please rate my solution.
Thanks.
Posted on Jul 01, 2009
barkencoa
Barry Coates
  • 3463 Answers
SOURCE: oven not heating up [fan works]
It wilbe a faulty oven element, you will need ti fit a new one.
It is located at the rear of the oven, behind a removeable cover.
Thankyou.
Posted on Feb 11, 2010
barkencoa
Barry Coates
  • 3463 Answers
SOURCE: My Belling oven has no heat, but the fan &
If the fan is working o/k, then there is little doubt that the oven element has failed.
This is quite common with fan assisted ovens.
The element is usually located at the rear of the oven compartment behind a removeable cover.
Posted on Mar 29, 2010
Testimonial: "Thanks "
I cannot get the big oven on my belling db90 to switch on. the clock is flashing 00:00 auto
Set the clock to manual....a hand symbol..... then try again....the oven wont work on auto unless you set time on and time off
tip
Common faults Belling XOU252
For all Free appliance repair videos visit our VIDEO TUTORIALS
1, If the Belling fan motor in the back of the oven is going round and the temperature light is on (normally little red light), but there is no heat then you will probably need a new oven element, these are generally very easy to fit and readily available from our website these can be tested with a electric meter.
To gain access to the BELLING element you will have to remove the back plate from inside the oven. Once removed you will see the fan and element, if you look closely at the element you will probably see a small hole burnt in it where it has blown. Sometimes however there is no evidence of a fault but the element is open circuit ie: broken inside the element casing, either way it will need replacing. Some elements will are fixed from inside the oven and some are held in place by nuts from the rear of the machine.
2, If your BELLING fan oven is getting warm but takes a very long time to cook or is burning the food more on one side than the other, then you need to check if your oven fan motor is working you will see the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven then you need To replace the oven fan motor is a little more expensive and a bit more involved.
3. If you have the opposite problem ie: your oven is over heating and burning everything then you will need to replace your BELLING oven thermostat
4, A quite common and easily overlooked answer is if your BELLING oven is not working at all ie: no heat and no fan then the chances are that someone has put the oven timer into AUTO mode, simply put oven back to MANUAL mode and all should be working again.
tip
Common faults on belling cookers
For all Free appliance repair videos visit our VIDEO TUTORIALS 1, If the Belling fan motor in the back of the oven is going round and the temperature light is on (normally little red light), but there is no heat then you will probably need a new oven element, these are generally very easy to fit and readily available from our website these can be tested with a electric meter.
2helpful
1helpful
My oven wont heat up
More than likely a faulty oven elementr.
This is located at the reae of the inner oven compartment behind a removeable cover.
6helpful
Belling synergie oven grill comes on oven fan comes on all lights are working but no heat in the oven temp 200 setting on the oven symbol all plugs have been checked.
I suspect tha the oven element is faulty.
To access it, you will find it located at the rear of the oven compartment behind a removeable cover.
Hope this helps you.
10helpful
Fan oven wont heat up
Thanks.
15helpful
3answers
Belling synergie. oven does not heat up. grill ok. think i need to set to manual but how???
cheers
will
Top Belling Ovens Experts
Marvin
Marvin
Lawrence Oravetz
Gil Shultz
Are you a Belling Oven Expert? Answer questions, earn points and help others
