Car Audio & Video Logo
Question about Car Audio & Video
Dixon Ammini8 amplifier. When I switch on, why does it pop the fuses?
There is no sound
Posted by George April -Mr. G2 on
  • Brad Brown Apr 17, 2021
    Hi George April -Mr. G2, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? i cant locate any information on the model that you have listed.
ray gallant
    Top Expert:
  • Car Audio & ... Master
  • 74,163 Answers
Check this link below
https://www.google.com/search?q=Dixon+Ammini8+amplifier.&oq=Dixon+Ammini8+amplifier.&aqs=chrome..69i57&sourceid=chrome&ie=UTF-8
Posted on Apr 17, 2021
1 Related Answer
Anonymous
  • 16 Answers
SOURCE: fuse pop when switch to hi side
Drawing too much amperage... Need a thicker wire with a higher amp fuse. Have a professional do it.
Posted on Apr 11, 2013
I have a dixon 8channel powered mixer model no.fx8-400 non of it's channels seems to work there's no sound what must i check
If it lights up when you turn it on, it won't be the fuse being blown. If there is no sound, not even hum, when it's turned up, it's probably the output section is blown and it needs to go to the shop.
Feb 01, 2017 • Dixon Music
Carb problems
check and see if all your carb jets or clean sound like some dirt got into one
Fuse pop when switch to hi side
Had a radio installed it flicks or pops frm time to time but this maybe causing my fuse to pop and my car wont start. Had put a relay switch on about a month ago.helppp
Hi.
If there is popping sound and the fuse blows when the radio is flickering, then it is usually a short in the stereo wiring. The short results in excessive power draw and blows the main fuse. The radio must be removed to check the wiring behind. In some less common case the radio itself may be shorted inside becuse a defective PSU. If you have installed an amplifier check also that the problem is not the amplifier ordinary power draw, in that case the problem is fixed installing a capacitor in the amplifier power wiring.
Xtant 3300x
It sounds like it's going into protection mode.
Do any of the channels pop when it's switching on and off?
If you power it up via a single 15 amp fuse (in series with the B+ line), does it blow the fuse when it powers up?
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
