Televison & Video Logo
Question about Samsung Televison & Video
Samsung UN55ES6100, replaced LEDs. Fixed no pic on right but it now has a red tint on the right side and depending on the image different image problems seem to occur. The old LED, right side had a blown LED. Looked like it arced or took a high voltage hit. I now also hear a high pitched squeal coming from the power supply board. All the caps look good. Nothing looks blown or cooked. Can a bad power supply board also cause funny image issues on just one side of the screen?
Posted by John Day on
    Top Expert:
  • Samsung Master
  • 76,849 Answers
If you wish to get some details; check the site linked here. Pull up older posts.
https://elektrotricks.blogspot.com/
https://electronicshelponline.blogspot.com/
faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent. Search the site by type in the brand name of your set, in its search bar at the right side column, and press enter. See it in either WebView, or by desktop. MobileView has no search box.
Posted on Apr 16, 2021
5 Related Answers
Anonymous
SOURCE: power light comes on - but NO IMAGE.. Power supply / inverter???
At first my tv would work for about 8 hours, then the backlight and audio would die. The light stays green like it is on. now it will work for an hour before it does it. I'm guessing it is the related to this problem. On the viewsonic store they have the PSU board, However it is out of stock. If you can get them to send you the part It is an extremely easy fix. As soon as I find a power supply I'm going to see if works.
Posted on Jan 07, 2008
Anonymous
  • 293 Answers
SOURCE: Hanns G 19" LCD monitor Screen Problem
D3mon,
Looking at the photo that you took... You've defintely got a damaged panel. My advised get a new one...saved you the headached and $$$....
Posted on Oct 11, 2008
Anonymous
  • 44 Answers
SOURCE: No Picture & No sound. Red LED, Green LED, Red LED.
If the power supply outputs are good! Then I would say the back light inverter is bad! If the screen stays black and does not come on.
Posted on Feb 28, 2009
Anonymous
  • 147 Answers
SOURCE: Polariod FLM-3232 Screen Flicker & High Pitch Squeal
replace all the capacitors in the power supply
board.you will see the capacitors bulge out on the tops.change all of them with a higher
voltage.
Posted on Aug 08, 2009
vinhson65
  • 257 Answers
SOURCE: Samsung LN-T2632H won't turn on.
Follow these steps to figure out what problem is.
When you turn on TV, look at the back and see if the back light on. If it is on, the power supply and inverter work fine. The suspection now is main board and T-con board (the small board on the middle-top of the panel)
To find the problem from the main board or not. Look at the power supply and measure Vs on - turn on the TV, this approx 5 vlt DC needs constant once you turn on the TV. If it is drop or unstable - main board problem - replace it.
If Vs on is good - disconnect the T-con cable from the power sup. If power sup stop clicking - T-con need replacing. Hope it help.
Posted on Aug 13, 2009
I have a Samsung 55" LED TV (un55es6100) and the red color is flaring up. Green/Blue are perfectly normal. All other tv functions are normal. Can someone please help me figure out what to replace?
Are you using component cables or HDMI? If component, make sure your red, green and blue are pushed in all the way. Too, make sure your red audio is not the red video. If hdmi is used try a new one. If these do not help unplug your t.v for 10-20 seconds and plug it back in. All else fails reset your t.v to default factory settings.
Red tint right side mitsubishi hc7900dw
first try doing a factory reset through the menu. if it persists and the tint has a relatively hard edge to it, you may have a broken light tunnel and it's casting a bit of a shadow on the image. you might need to bring it in for repair, especially if it's under warranty
2answers
Viewsonic VP930b color problem - Red tint
Go to the setup menu on the LCD panel by pressing button 1 on the front. See if there is an option to reset the lcd to factory settings. Reset it and report if it helps not.
2helpful
2answers
Green tinted people
The only time I have had issues like this was because of the Component Cables not being in the right position (the Red and Blue connections switched), or a bad Component Cable where the Blue Connection is not receiving a signal. Swap out the cable to be sure and double check that it is properly installed. Green to Green, Red to Red , Blue to Blue.
Hope this helps,
skyassoc
Lacking red
Hi
in this case you have defective CRT Circuit System, CRT means The Cathode Ray Tube... Circuit system. this need to diagnose the System IC. if you know how to repair electronics appliances i can teach you how to fix this issue..
Thanks!
Colors bleeding, red tint around images
The liquid coolant between the guns and the lenses may be fogged, low, or both. If the red gun has fogged coolant, you'll see red fringing around objects. It can be drained and refilled with new coolant, but it's gotta be the right stuff. You may be able to get some from a junk set, as I have done with success. Shine a light into the front of each lens. If the liquid has gone bad, you'll be able to see it.
Left half image has greenish tint, other half fine XV Z9000U
I am having the same issue, did you ever get yours fixed and if so how please?
Shannon
5helpful
2answers
Picture calibration settings for 42lg70
Picture Menu
Picture Mode: Expert1
*Backlight: 16
*Contrast: 83
*Brightness: 53
Sharpness: 50
*Color: 55
*Tint: 0
Expert Control
  • Fresh Contrast: Off
  • Noise Reduction: Medium
  • Gamma: Medium
  • Black Level: Low
  • Real Cinema: On
  • TruMotion: Low
  • Color Standard: HD (N/A w/HDMI)
  • White Balance: Warm
  • **Method: 10-Point IRE
    • 10 IRE
      • **Red: 1
      • **Green: 2
      • **Blue: -16
    • 20 IRE
      • **Red: -6
      • **Green: 0
      • **Blue: -7
    • 30 IRE
      • **Red: -5
      • **Green: 0
      • **Blue: -4
    • 40 IRE
      • **Red: -8
      • **Green: 0
      • **Blue: -4
    • 50 IRE
      • **Red: -4
      • **Green: 4
      • **Blue: -4
    • 60 IRE
      • **Red: -6
      • **Green: 6
      • **Blue: -5
    • 70 IRE
      • **Red: -8
      • **Green: 3
      • **Blue: -10
    • 80 IRE
      • **Red: -8
      • **Green: 7
      • **Blue: -16
    • 90 IRE
      • **Red: -9
      • **Green: 5
      • **Blue: -18
    • 100 IRE
      • **Red: -10
      • **Green: 4
      • **Blue: -9
Color Management System
  • Red Color: 0
  • Red Tint: 0
  • Green Color: 0
  • Green Tint: -15
  • Blue Color: 0
  • Blue Tint: 11
  • Yellow Color: 15
  • Yellow Tint: 2
  • Cyan Color: -15
  • Cyan Tint: 0
  • Magenta Color: 0
  • Magenta Tint: -1
lg70 nice tv excellent processor just to bad there is no intensity control on color management oh well still better than what the three s are pushing block out the hype lg will be number 1 in a few years haters are starting to come around and well leds coming,
p.s. i dont work for lg just tired of losers bashing stuff because they dont own it.
im isf certified those settings are right on the money straighter than a ruler
Marvin
Marvin
