If it is like mine, the CR2032 battery in the base station only lasts about 6 months, whereas the one in the outdoor unit lasts over a year. Try this though. Remove the batteries from both units. Replace the battery in the indoor unit and then in the outdoor unit. It should re-register it.
Steve, thanks for that info on the reset button , I go through this every time I change batteries. I put a note on the back of my Springfield temp now.
Did you reset the sensors after replacing the batteries? Bring the sensor inside and close to the main unit. Replace batteries on both units. Use a thumb tack and stick it into small reset hole near battery compartment to reset both units. If that doesn't work, your sensor needs more troubleshooting or needs to be replaced.
I have experienced the same with numerous different, "quote un quote" atomic clocks! Please don't forget that this sender unit, that goes outside, generates a RF Singal to be received by the clock inside. This unit transmits a signal 433 MHz signal approximately every. 3 minutes, and after so many years the sender unit's RF section(electronics) just goes out or no longer function properly or not at all! The transmitter/sender for this model number, according to "3M" is obsolete and can no longer be furnished, DRATTS !!!!!
